Home > Td5 > Switch location |
mfspannerman Member Since: 18 Nov 2012 Location: Suffolk Posts: 36 |
This question has probably been asked loads before but carn't find anything??
I have an 02 defender i am looking to add extra lights so need to add extra switchs i am just trying to work out what switchs people have used and where they have mounted them? Make tracks and get moving!! PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
8th Jan 2013 5:53pm |
whelo Member Since: 06 Jan 2013 Location: Bridgend Posts: 34 |
Hi, i used a front fog switch, http://britishparts.co.uk/products/6034-sw...000540LNFG
I had it somewhere else alot cheaper, it fits in the centre dash top left, looks like it came out of the factory. Other option is http://www.mudstuff.co.uk/Td5_Fascia_Plate.shtml I've also fitted this with the 6 carling switches, looks neat enough. Jason Getting there, slowly.. |
11th Jan 2013 12:06pm |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
There is a photo of the location of my spot light switch (came with the TR), great if you dont have any spact on the new style dash...
http://www.defender2.net/forum/topic14780.html |
11th Jan 2013 12:27pm |
This is a better pic of the switch http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1c23ae17f6
But i did find it cheaper somewhere, i'll try & find the receipt weekend. Jason Getting there, slowly.. |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
http://www.rimmerbros.co.uk/Item--i-YUG000540LNF
Is the best one but it ain't cheap |
11th Jan 2013 2:08pm |
When I got my 2002 Td5 it had a few extra holes in the centre console, the police who had it before had been a bit quick off the mark at plonking switches wherever They had put switches in on the flat bit at the front below the radio between the cigarette lighter and the headlamp levelling switch. I put an extra lighter socket(12v permanent with the original 12v ignition switched next to it), 2 rectangular blanks from off a Discovery electric window console, went into 2 empty holes which I then cut 2 smaller rocker switches into to control my stewarding lights and an overide on the heated front screen. Another hole is filled with a switch for heated mirrors. Quite busy but fairly tidy. On the front of my cubby box I made a plate to carry a pair of toggle switches to control my battery monitor and my battery charging relay.
With ingenuity you can keep the dash tidy and also functional but I did manage to buy my LR front screen and 2nd front lights switches for a reasonable price last year before they became silly money. Another place to put switches/controls is on the fuse board panel, my Eberspacher controls are on there. |
11th Jan 2013 2:11pm |
Thought so, i'm too tight to pay that much for a switch. Just wish i'd bought some more now. Jason Getting there, slowly.. |
11th Jan 2013 6:08pm |
Thank you all for your replys! I have found this on eBay was wondering if anyone knows it would fit between the fag lighter socket and the head light switch?
Look at this on eBay: LAND ROVER DEFENDER SWITCH MOUNTING TRIM PANEL http://bit.ly/VQBuO8 Make tracks and get moving!! PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
Not sure, it's the one from the RHS of a pre 2001 Dash. Used to have Fogs and Hazzards in it. Old Lucas style switches like you used to get in Mini and MGBs
11th Jan 2013 6:11pm |
You'd b better putting it on the right hand side. Might fit in the space under the radio? or th switches might, bit fiddly.. Jason Getting there, slowly.. |
11th Jan 2013 6:21pm |
Yeah that what I assume it was for but wondered if it would fit under radio as you can buy that and 3 switches for the same money as a carling switch holder! Just a thought? Make tracks and get moving!!
11th Jan 2013 6:44pm |
Its probably worth a punt at £4.50.
11th Jan 2013 8:01pm |
