Home > Puma (Tdci) > ABS & Traction Control
Page 2 of 4 <1234>
jst
as MSE said ^^^
its an option and ABS and TC come together. std on XS.
TC works across axle only (although the newer Bosch system being worked on works on all 4 wheels)
its also good a breaking rear calipers - TC working when reversing!!!
its works at all speeds once you have gone over the 8kph turn on speed! (hence light on dash for ABS goes off at 8kph) Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #15044 3rd Sep 2009 8:19pm
AndrewS
alantd wrote:
AndrewS wrote:
Simples You drive into mud/snow,
Surely the TC only kicks in when the wheels are spinning at different speeds, not when they're generally spinning.
This is correct.
alantd wrote:
The TC isn't going to brake both wheels at the same time is it?
It will apply the brakes to the wheel that is turning faster.
alantd wrote:
I assumed it didn't monitor differences between front and back.
It doesn't
I don't think the diffs are up to the forces involved thats all Thumbs Up
When driving off road at some point you will find that you will have to apply some gas. Lets say going through a snowdrift. At some point one of the tyres will loose traction the TC will apply the brakes to this spinning wheel, the drive force will be transfered through the diff to the other wheel that has grip, this wheel will then push the car forward Thumbs Up
Now can you imagine the forces that are involved in the above scenario You have a spinning wheel that has just been stopped, the opposite wheel with grip plus the load of the car on it is being forced to turn. The poor diff is under a lot of stress. And that was just for that split second. This will happen 20 or 50 times a second (not sure of the exact pulse rate) The diff need to be very strong to endure this punishment and when diffs are failing on vehicles that don't leave the tarmac the off road vehicle diffs don't stand a chance.
The fuses for TC/ABS are under the drivers seat they can be pulled and the vehicle will drive fine. We had to do this in Morocco when the front axle exploded on the Utility.
When the diffs fail on Chelsea I will get them replaced under warranty remove them and get Mr Ashcroft to supply me with decent diffs and drive shafts all round. Thumbs Up
Sonic demonstrating wheel spin
Post #15069 4th Sep 2009 9:33am
jst
i agree with all your above post bar the fact that the spinning wheel with no grip will not necessarily be brought to a stop (it may be but not always) the TC just has to make the spinning wheel the harder option so the power goes the other way. how much breaking and how frequent TC works depends on level of grip of the other tyre. that of course doesn't get over the fact that the forces involved are massive
i totally agree that the diffs are useless. My first one went soon after an off roading session with a fair amount of TC working. since then the replacement has been fine until it did some more 'serious' off road - by serious i mean enough to induce alot of TC activity and now the 'new' rear diff is starting to moan a little. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #15086 4th Sep 2009 12:24pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i had a chat to a land rover experience instructar about my lack of T/C and he said that when it kicks in it can (and by can he ment not always) put the brakes on harder than you would be able to do with as much force on the pedal, this can create a shock wave traveling through the drive train, i take from this that the old land rover saying of as slow as possable but as fast as nessasery still applys with the puma's. no T/C hasn't stop'd me yet and i'm still on general grabbers!
Post #15091 4th Sep 2009 1:56pm
mse
The worry with the diffs is the failure outside of warranty - or when you havent got access to a dealer Mike
Post #15098 4th Sep 2009 3:50pm
jst
now thats something to listen too meant nicely! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #15113 4th Sep 2009 7:42pm
AndrewS
Wink
Post #15114 4th Sep 2009 7:44pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Are the 09/10 diffs any stronger than the first puma diffs or is it a case of after market diffs to cure the problem! Andrew now the utility has gone what are you using for serious off road work.
Post #15154 6th Sep 2009 8:56pm
jst
mine is a 09MY and rear diff went, they are all same as, there was a batch of faulty diffs mind which contributed to the problem. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #15225 8th Sep 2009 10:37am
AndrewS
Chelsea
and The Red Pearl
Post #15286 9th Sep 2009 8:44pm
jst
having already replied didn't they change all rear diffs (may of been front) to 4pin ones on the 09 MY? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #15318 10th Sep 2009 12:36pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I'm not sure if resurrecting this thread is the right way to go or not so apologies if there's already an answer on the forum I haven't found.
I've recently had a half day on the Experience course at Dunkeld and in discussion with the Instructor they suggested that up to 2012 TC was an option on the Defender. I have a MY2012 110 USW XS, other than finding a scenario where TC should kick in is there any way to check if I have this or not?
This thread suggests that I should have it, however the most recent posts are 2009 so I have no idea if something has changed since then.
Thanks
Keith Keith
Post #568722 4th Oct 2016 8:16pm
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
I believe if you turn the key to the position before start (as you would to warm the glow plugs) your ABS and TC light should stay on for a few moments and then go out.
If your Defender isn't fitted with either, the lights won't ignite. Give the manual a read it may shed a bit more light than I can Smile
Post #568731 4th Oct 2016 8:29pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Not 100% on this, (but probably 99%) but so far as I know, but in order to have Traction Control, you must have ABS. With ABS, you will have 2 brake lines to your rear differential, non ABS will only have 1. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #568741 4th Oct 2016 9:07pm
agentmulder
Kuwait
Pretty simple to check without having to skid.
Look at the swivel housing top pin, if you have TC/ABS there will be a cable running from it back towards the vehicle front. Don't get it confused with the diff breather though.
Not having it, I'm not sure where it is located on the rear?? Solved the bowel problem, working on the consonants...
Post #568754 4th Oct 2016 9:30pm
Page 2 of 4 <1234>
