Home > Maintenance & Modifications > 20% Discount on rustproofing @ RUSTMASTER !
Page 2 of 4 <1234>
SULLY
2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thanks Chalky. Thumbs Up
My delivery date should be within the next 2 weeks. As soon as I know I will contact them and book it in.
Very Happy
Post #15379 12th Sep 2009 9:57am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
chalky wrote:
Right !
That's us done, mines booked in, call in your own time to arrange when is best for you,
I belive some one has already had theirs done ? So come on spill the beans what are your comments ? Observations ?
Cheers !
Hi Chalky,
It was me, very pleased and they do plenty of Defenders so do a thorough job. Kev (I think), the technician was only too keen to talk me through what he was going to do, how it protects your Landrover and showed all the problem areas where mud accumulates and accelerates the rust.
I got it done yesterday, it's still a bit tacky so not really had a good look but 1st impressions are very good. It only went where it was supposed to go also and where there was some overspray this was cleaned off.
Basically they do exacly what they say they do, I made sure mine was as clean as possible before going so their time spent was rustproofing and not cleaning. Very pleased Very Happy
I will get some pictures once it's cured (it's shiny now)
Finally a big thankyou for organising the group discount Chalky and Rustmaster.
Oh and you get a neat hologram to stick above your tax disc, it's not very big and shows it has had a quality rustproof. (Listen to Mike on how to put it on because I screwed mine up, they are tamperproof so if you stick it don't pull it off if it's not square)
Steve
edit: i took my mountain bike, loads of single track, 2 hours out to a pub for a pint and sandwich. by the time i got back it was finished. nice day out. i got lost in the woods nearby but luckily took the tom tom in my rucksack.
Post #15384 12th Sep 2009 2:51pm
Steve B
hi chalky,
when you booked in? i'm off next week tue to fri, im only 1hr 20min from rustmaster if your into mountain bikes then i might come for a day out.
Post #15391 12th Sep 2009 8:49pm
alantd
Just booked myself in for late October.
Nice one Chalky - this is something I wanted to do but couldn't really spur myself into action until you secured the discount. Thumbs Up Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #15453 14th Sep 2009 7:32pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Booked mine in today for early November. Thanks again Chalky for all your work on this. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #15512 15th Sep 2009 9:30pm
Mark
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Any slots left on this deal ?
Post #15560 16th Sep 2009 4:06pm
chalky
Guys,
thanks for all your positive response, I have spoke to Michael today, just needing to keep tabs on who is booked in and when we also need to tell him when booking that we are from this web site so he can honour the 20% discount.
And yes there are spaces left as this will just run and run, he gas agreed to honour this until further notice,
I'd justlike to say thanks again for all your positive input and taking advantage of this offer.
I think I'm going to do another one soon for the rear heavy duty corner bumperettes with correct bolt holes for the TDCi DEFENDER.
Let me know DEFENDER XS CSW 08 TONGA GREEN
Post #15563 16th Sep 2009 4:52pm
Mark
Thanks Chalky
Post #15606 17th Sep 2009 5:34pm
SULLY
Booked in for Thurs 1st Oct.
Thanks again Chalky Thumbs Up
Post #15827 24th Sep 2009 8:04am
SULLY
Now the 9th Oct as Michael was double booked. Hope it can last two weeks without the dreaded rust eating it away. Laughing
Post #15866 24th Sep 2009 8:27pm
alantd
What are the main things I should ask Michael to specifically cover. I'm sure that his standard approach is pretty thorough but are there any specific things I should ask him to pay special attention to? One that started out as a 2.4 TDCi 110 XS
Post #16375 7th Oct 2009 1:27pm
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Rustmaster know the Defender well so it is doubtful they will miss much.
I have posted a list of 'must be squirted into' somewhere in the rustproofing threads.
The rear crossmember is a must. It is multi-layered and so easy to miss a bit. If you stick your finger into the ends of the crossmember you will find a blind pocket, ideal to clog with mud. Make sure this is done.
Chassis legs behind the front wheels, both inside & out.
Remove the rubber jacking point bungs in the front of the chassis so good access can be gained.
remove the two grommets by the windscreen wipers & ensure they are squirted into. This will protect the top of the bulkhead.
Under the bonnet on the bulkhead is a black paper round sticker. punch a hole through the paper to reveal a hole. This gives additional access to the bulkheaed.
The door pillars need a good squirt. Access is from underneath.
squirt inside the side bars
I removed the door trims from all doors so good access can be gained. Not really nessasary but I am fussy. I also put standard waxoil right across the bottom of the doors on the inside as they are now steel. Whilst the door trims were removed, I also removed the rubber seal between the door & the bottom of the glass, as the LR seal does not fit too well & will allow loads of water in. I pugged it all up with mastic & re-fitted the rubber.
I also removed the mud flaps & rear step before getting it done.
Take some old clothes & hang about & watch. They don't mind at all. You can then be assured that everywhere has been done to your satisfaction.
Post #16528 10th Oct 2009 12:28pm
alantd
That's great - thank you. One that started out as a 2.4 TDCi 110 XS
Post #16530 10th Oct 2009 1:34pm
DelD
Do they have insurance? A friend of mine said they use a two post lift which he said is not safe to lift Land Rovers. Is this true? He said that with the rustproofing process the pads would get very slippery and the Land Rover could easily slip off.
DelD
Post #16614 12th Oct 2009 1:18pm
chalky
That's a bit of a spurios first post DelD ?
I'm sure one of the forum members who have already taken advantage of this offer will confirm the type of lift used?
I'm sure Michael will be the best person to speak to regarding his liability insurance !
Can you confirm that you are not a competitor casting doubt amongst the forum !
I mean where else would a deserning Defender owner go to have such a treatment lavishly applied to their pride and joy ? DEFENDER XS CSW 08 TONGA GREEN
Post #16644 13th Oct 2009 10:26am
Page 2 of 4 <1234>
