Home > Td5 > td5 ecus |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Is the temperature gauge crazy I suppose is the first question? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th Dec 2012 10:01pm |
laralandy Member Since: 17 Oct 2012 Location: dorset Posts: 28 |
Lol yeah temp guage problem one. Abs tc not really a problem till the mot in 12months. im told its an intermittent fault which i believe to be true as i guess it would have failed on mot if it was on all the time. unless its possible to remove the warning bulbs!!
19th Dec 2012 10:05pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
If the ECU is the later NNN type it can be reprogrammed from a Disco to Defender. http://www.yorkshireoffroadclub.net/
20th Dec 2012 12:17am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Did not think a 2001 X-Tech had ABS and TC.
Andy |
20th Dec 2012 3:06am |
hmmmmm. interesting. The lights are illuminated though. Unless this is the defender ecu causing it to think it has abs traction control etc?? Will the injector wiring harness really cause this problem or just the ecu? A chap on the dreaded bay is selling nnn or msb (what ever these are) ecus saying they are plug and play?? is that correct?
20th Dec 2012 6:19am |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Thought ABS & TC was an option on all TD5s look for the wire sensors on the inside of the wheels.
20th Dec 2012 6:45am |
yeah it does have abs, i can see from the servo. So is there anyway to get a defender temp guage to work with a discovery ecu??
20th Dec 2012 6:57pm |
Why ask a question if you're not reading the answers ? http://www.yorkshireoffroadclub.net/
20th Dec 2012 7:55pm |
ah sorry about that, im using my phone and its useless, i didnt see the answer. Ok well i will have to try get it reprogrammed or plump up the cash for the ecu on ebay which is supposed to be plug and play and include a power remap. 395 for the msb or 495 for nnn. whatever that means.
cheers all |
20th Dec 2012 8:56pm |
MSB and NNN are the two types of ECU.
MSB are the older ones that can not be reprogrammed they physically have to have a chip removed and new one soldered in. NNN are the later ones that can be reprogrammed Andy |
20th Dec 2012 9:06pm |
If you look on the ECU there should be a part number, if it starts NNN such as NNN000120 then it can be reprogrammed as a Defender ECU. If it starts MSB then it can't be changed from one to the other as far as I am aware.
Any Land Rover specialist should be able to change it over for you if it's an NNN type, shouldn't cost much as it only takes a few minutes with an Autologic or similar unit. I got two done in around 20 minutes including putting in the injector codes and training them to the immobiliser. The ECUs come up on ebay regularly, you can usually get them for under £200. This one for example... http://www.ebay.co.uk/itm/140898897603 I'm sure one of the forum sponsors will be able to help either way. Given the odd history it would be worth checking the injector codes on the engine actually match those in the ECU. You just have to take the rocker cover off the top of the engine and make a note of them (printed on the top of each injector). http://www.yorkshireoffroadclub.net/ |
20th Dec 2012 9:07pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
You can't programme a Discovery ECU to a Defender one.
21st Dec 2012 10:32am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Yes you can... Apart from NNN000250 as there is technically no Defender map - as that ECU is unique to a Disco. Any NNN500020 or NNN000120 can be 'reflashed' to a Defender or Disco. As a bit of bodge, you can convert a MSB none flash as wel.. With a Disco Cal on a Defender the temp gauge will work the wrong way round. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
21st Dec 2012 10:39am |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Ian
If I used a discovery ecu you say the temp gauge works backwards. Maybe that is what I need then. Phil |
22nd Dec 2012 10:03pm |
