Home > Puma (Tdci) > Intercooler hose worn through |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Lost all power today as the IC inlet hose rubbed through on the steering arm. This was fine after 12000km but has now gone at 26500km's Spent 6 hours limping 210km back to somewhere I could get it fixed Will post up pic's when I get a chance.
I think this issue has already been mentioned. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
21st Aug 2009 10:30am |
Pic's of IC inlet hose where steering joint rubbed. It's been cut and a piece of metal pipe inserted and then calbe tied out of harms way. Puma's purring again:)
Click image to enlarge Click image to enlarge I'm wondering now if there are Silicon hoses available for the Puma or better yet a metal pipe. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
22nd Aug 2009 8:53am |
Leo Member Since: 25 Apr 2009 Location: under an acacia Posts: 22 |
Good job fixing the pipe, but there's a lot of rust on your car.
22nd Aug 2009 9:27am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
most of the red stuff is Auatralian dirt and dust! 2.4 90 XS
22nd Aug 2009 9:37am |
22nd Aug 2009 10:38am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Just checked mine and it was starting to wear through.
Now cable tied out of harms way. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
23rd Aug 2009 12:54am |
Our's is ok got a good 1" clearance between pipe ane column,but did notice a slight leak on n/sswivel wiper seal 2.4 90 XS
23rd Aug 2009 10:17am |
23rd Aug 2009 11:03am |
Thanks Derek.I'd better keep checking,did you say they'd tierapped it out of harms way? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
23rd Aug 2009 12:15pm |
24th Aug 2009 10:07am |
Thanks Derek 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
24th Aug 2009 1:01pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Allisport has just started to sell silicone intercooler hoses in black or blue drop them an email and he could give you a price to ship a set |
24th Aug 2009 5:17pm |
25th Aug 2009 11:39am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
21000 kms on our Puma so I decided to check the hose. There is a slight mark i.e. a clean piece on it just above the bolt on the coupling at the end of the steering column. So I guess there is contact there, though very slight. I raised it slightly with cable ties and put some black duck tape where the clean spot was. I would say that a couple of layers of duck tape should see you alright until there is a permanent fix for this.Personally I think that by slightly shortening the pipe at the end closest to the bulkhead, it should tighten it up and take the sag out of it. I will report this to the main dealer by e-mail and put it on the check list for the next service. If they say there is a replacement pipe I will post it here. 1982 88" 2.25 diesel
26th Aug 2009 10:15pm |
