Home > Maintenance & Modifications > Better lighting on dipped headlamps suggestios please?
BigWheels
Driving through recent flooded patches of roads, & having to dip my headlights using standard LR bulbs I have driven into those areas & had sheets of water wash over the front.
What bulbs & other lights, totally waterproof, could I have to improve front lighting with the headlamps on dip. I don't want to go for expensive replacement headlamps. Just brighter. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #189011 27th Nov 2012 7:38pm
keith
Checkout PRI racing . Com . You want PIAA extreme white H4
Post #189024 27th Nov 2012 8:27pm
mobilecentre
Put relays on headlights
Buy some Wipac crystalls
Post #189051 27th Nov 2012 9:00pm
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
@mobilecentre "relays on headlights" interesting, what would this do?
Post #189058 27th Nov 2012 9:12pm
ickle
allow you to fit big bulbs!
Post #189062 27th Nov 2012 9:16pm
mobilecentre
Switch the power via relays. So making the cable run shorter and reducing resistance so allowing more juice to get through!
Post #189063 27th Nov 2012 9:17pm
mobilecentre
And fit bigger bulbs without smoking your switch
Post #189064 27th Nov 2012 9:17pm
TD5_90
I see. Well, I don't really! Rolling with laughter sorry bigwheels if this hijacks your thread, hopefully this helps your question ...
So what relay would allow what wattage? Standard is H4 55w?
Post #189074 27th Nov 2012 9:34pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
2 x H4's on full beam = total of 120 watts on 12v circuit = 10 amps. Using a 30 amp relay would allow total of 360 watts maximum on full beam.
H4's on dipped would be a total of 110 watts.
Of course fitting bulbs that would allow maximum current to be used are illegal on the public highway in the UK.
The above calculations depend on me correctly remembering my physics from 50 years ago Rolling with laughter LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #189082 27th Nov 2012 9:45pm
ickle
So theoretically i could have fitted 100/80 watt Ring rally bulbs in my relayed crystal headlamps, but as that's illegal, it will have to remain a theory.
Post #189085 27th Nov 2012 9:49pm
TD5_90
Whistle
Does anyone know why my mates 300tdi headlights come on with the sidelight? It's like a softer glow than dip.
Post #189093 27th Nov 2012 10:06pm
It's called dim-dip and was a legal requirement for a while in the '90's. Darren
Post #189100 27th Nov 2012 10:19pm
110SEB
TD5_90 wrote:
Whistle
My old 90 N reg HT had that.
Post #189107 27th Nov 2012 10:38pm
TD5_90
Thanks. I quite like it, would it be difficult to wire up?
Post #189108 27th Nov 2012 10:45pm
WelshGas
Ickle - yes it would have worked and have been electrically safe to fit 100/80 bulbs with a relayed light system - BUT not for use on the Public Roads. Thumbs Up
Big Wheels - what about under-bumper fog lights for road use. I have a pair of X-Lights from X-Eng fitted on plates below the bumpers so that they don't project forward of the bumpers. Nice light , no glare, do not affect off-roading capability BUT also not expensive compared to some auxiliary lights. Thumbs Up LANDYWATCH
Post #189138 28th Nov 2012 6:35am
