Home > Maintenance & Modifications > Better lighting on dipped headlamps suggestios please? |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2212 |
Checkout PRI racing . Com . You want PIAA extreme white H4
27th Nov 2012 8:27pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Put relays on headlights
Buy some Wipac crystalls |
27th Nov 2012 9:00pm |
TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89 |
@mobilecentre "relays on headlights" interesting, what would this do?
27th Nov 2012 9:12pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
allow you to fit big bulbs!
27th Nov 2012 9:16pm |
Switch the power via relays. So making the cable run shorter and reducing resistance so allowing more juice to get through!
27th Nov 2012 9:17pm |
And fit bigger bulbs without smoking your switch |
I see. Well, I don't really! sorry bigwheels if this hijacks your thread, hopefully this helps your question ...
So what relay would allow what wattage? Standard is H4 55w? |
27th Nov 2012 9:34pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
2 x H4's on full beam = total of 120 watts on 12v circuit = 10 amps. Using a 30 amp relay would allow total of 360 watts maximum on full beam.
H4's on dipped would be a total of 110 watts. Of course fitting bulbs that would allow maximum current to be used are illegal on the public highway in the UK. The above calculations depend on me correctly remembering my physics from 50 years ago LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
27th Nov 2012 9:45pm |
So theoretically i could have fitted 100/80 watt Ring rally bulbs in my relayed crystal headlamps, but as that's illegal, it will have to remain a theory.
27th Nov 2012 9:49pm |
Does anyone know why my mates 300tdi headlights come on with the sidelight? It's like a softer glow than dip. |
27th Nov 2012 10:06pm |
It's called dim-dip and was a legal requirement for a while in the '90's. Darren
27th Nov 2012 10:19pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
My old 90 N reg HT had that. |
27th Nov 2012 10:38pm |
Thanks. I quite like it, would it be difficult to wire up?
27th Nov 2012 10:45pm |
Ickle - yes it would have worked and have been electrically safe to fit 100/80 bulbs with a relayed light system - BUT not for use on the Public Roads.
Big Wheels - what about under-bumper fog lights for road use. I have a pair of X-Lights from X-Eng fitted on plates below the bumpers so that they don't project forward of the bumpers. Nice light , no glare, do not affect off-roading capability BUT also not expensive compared to some auxiliary lights. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
28th Nov 2012 6:35am |
