Home > Puma (Tdci) > Front differential on Puma |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
P.S Truck is an early 2008 USW so i'm pretty sure it has the two pin diff at the front.
24th Nov 2012 6:10pm |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
all LR have a 2 pin diff (except p38) we trial on standard 2 pins and there fine
24th Nov 2012 7:02pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8140 |
not quite Simon, well not all LR
later Pumas have 4 pin, early 110s had 2 pin front and 4 pin rear. V8 90s ran 4 pin (although only rear i think) Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Nov 2012 7:22pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2438 |
my 07 has a 2-pin front and no probs after quite amount of trial even with larger tires. Puma 110" SW
24th Nov 2012 9:31pm |
we seemed to stuggle with them when a 110 was fully loaded going down a steep limit of traction drop, got through a few until a 4 pin was fitted. they were 07/08 models. Cheers
24th Nov 2012 9:34pm |
well you learn something everyday |
25th Nov 2012 11:39am |
chrisbowler Member Since: 25 Jun 2011 Location: wales Posts: 101 |
4 pin diff is speced as a heavy duty option only part number tbbooo280 £1163.41
Can be fitted to any PUMA or defender Chris bowler |
28th Nov 2012 9:06pm |
nikojo Member Since: 05 Aug 2011 Location: Madrid Posts: 75 |
are the ashcroft's 4 pin??
29th Nov 2012 3:32am |
Ashcroft certainly spec a 4 pin diff. I'm going to have a chat with them see what they can offer - I'll post what I come up with. |
29th Nov 2012 8:41am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 |
Hi,
We are out of stock of the 4 pins at the moment, we have 50 in production but you may as well buy the ATB, it's not much more money and you have the added bonus of addition traction being a limited slip : http://www.ashcroft-transmissions.co.uk/in...ductId=259 Dave Dave |
29th Nov 2012 6:47pm |
