![]() | Home > Puma (Tdci) > Front differential on Puma |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
P.S Truck is an early 2008 USW so i'm pretty sure it has the two pin diff at the front.
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
all LR have a 2 pin diff (except p38) we trial on standard 2 pins and there fine
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8213 ![]() ![]() ![]() |
not quite Simon, well not all LR
later Pumas have 4 pin, early 110s had 2 pin front and 4 pin rear. V8 90s ran 4 pin (although only rear i think) Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2467 ![]() ![]() ![]() |
my 07 has a 2-pin front and no probs after quite amount of trial even with larger tires. Puma 110" SW
we seemed to stuggle with them when a 110 was fully loaded going down a steep limit of traction drop, got through a few until a 4 pin was fitted. they were 07/08 models. Cheers
well you learn something everyday ![]() |
chrisbowler Member Since: 25 Jun 2011 Location: wales Posts: 101 ![]() |
4 pin diff is speced as a heavy duty option only part number tbbooo280 �1163.41
Can be fitted to any PUMA or defender Chris bowler |
nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 ![]() |
are the ashcroft's 4 pin??
Ashcroft certainly spec a 4 pin diff. I'm going to have a chat with them see what they can offer - I'll post what I come up with. |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 261 ![]() ![]() |
Hi,
We are out of stock of the 4 pins at the moment, we have 50 in production but you may as well buy the ATB, it's not much more money and you have the added bonus of addition traction being a limited slip : http://www.ashcroft-transmissions.co.uk/in...ductId=259 Dave Dave |
