Home > Puma (Tdci) > SVX style headlights - aux high beam lamp - LED replacement
Page 5 of 5 <12345
mobilecentre
The big question is can the market support the price point for us to "risk" the level of investment to produce this.
Ten years ago when we introduced a set of LED lamps for Defender at £200 everyone said we were mad
When we introduced LED headlamps six years ago at £1800 per set everyone said we were mad
Today you can get a set of LED lamps to suit Defender for around £100 and a set of LED headlights from £275
To bring the driving lamp to market will require specialist tooling just the same as Land Rover had to make which is not cheap and in turn will make the driving lamp more expensive than the headlight!
Post #367526 27th Oct 2014 3:10pm
ericvv
A pity, but understandable. There never will be thousands of Defenders with 1. the SVX style front installed, and then 2. interested to pay for this conversion... Guess you will get to dozens, maybe a few hundred at best?
Not the end of the world, because the combination of LED headlamps on high beam complemented by the halogen aux high beam are doing a perfect job to brighten up the road more than really needed.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #367536 27th Oct 2014 3:58pm
pbrinkmann
Greece 2007 Defender 110 V8 Petrol SVX Station Wagon Auto Santorini Black
Hi guys I know this thread has been dead for 6 years now but has anybody figured this out? Is there a compatible 90mm led high beam for the SVX front on the market?
Post #885591 15th Feb 2021 7:27am
Page 5 of 5 <12345
