Home > Td5 > Door striker
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Door striker
Passenger door difficult to shut, suffers bounce back and doesn't engage. Dealer says plastic coating on striker pin has worn through and dropped off leaving bare pin. Can find strikers at £4.91 on eby. Question.....is there a replacement plastic bit available to refurb striker.
Many thanks
Post #180098 29th Oct 2012 3:06pm
No, but at under a fiver for a new one I'm not sure it'd be worth the effort.
Alternatively, I can recommend the shiny stainless steel X-TROUSER!
 Darren
Post #180100 29th Oct 2012 3:13pm
chipmunk
Thanks Darren, just found the extensive thread on this forum regarding striker. Having ruined a pair of L.v.s by getting the rear pocket caught 'mid jump' and ripping the a..e for 6ins (the pocket stitching survived intact) , also ruining the seat belt I'm sorely tempted by these. I love shiney stuff too (but not overdone a la SVX, Rage Rover etc etc) and hate rust/staining. Just off to have a can of Carlsb... Extra to lessen the guilt at ordering them and ease the wallet opening. Cheers.!!!
Post #180106 29th Oct 2012 3:53pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
What an absolutely fantastic idea - just read the extensive thread too - at last a solution to the bounce back from the rear doors (hopefully)!!!! 2001 TD5 110 DCPU in Bonatti Grey
Post #180129 29th Oct 2012 5:22pm
Arbman Al
I wrapped insulating tape around mine when the plastic wore away.
Been fine for 6 months now! 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #180243 29th Oct 2012 10:54pm
K9F
Decent heatshrink should sort it! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #180244 29th Oct 2012 10:57pm
daviec1
Bought yesterday, received today, fitted today (one side a little bit fiddly - needed shims).
And now, solid thunk, no bounce back and no springing open in transit when I go over bumps! 2001 TD5 110 DCPU in Bonatti Grey
Post #180659 31st Oct 2012 2:20pm
chipmunk
It's amazing how often and how long we put up with seemingly unfathomable faults only to look through these pages and find out that someone somewhere has cured them ages ago, and so simply. This and other similar websites are so invaluable. Three cheers!!!
Post #180667 31st Oct 2012 2:37pm
geobloke
Re: Door striker
Many thanks
Hi Chipmunk, I have had the very same problem for as long as I have had this 02 plate 110, infuriating problem to have. This is what I did: http://forum.landrovernet.com/content.php/...How-to-Fix - and it worked a treat. Have a go before you spend any hard earned. Good luck.
Post #192289 10th Dec 2012 12:16pm
chipmunk
Hi Geo', thanks for that. Again a very comprehensive answer. I tried some of the cures involving the striker itself but to no avail. This looks like it will be the answer and I'll try it when the hail and snow stops long enough to do it. My passenger door doesn't get used enough I think, and maybe the latch lock is seizing due to that lack of use. I'll report back. Many thanks for the info and trouble taken.
Cheers.....hic! Thumbs Up
Post #192311 10th Dec 2012 1:24pm
geobloke
No problem, let us know how you get on.
Post #192322 10th Dec 2012 2:07pm
