Home > Puma (Tdci) > Diff Lock Light
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Diff Lock Light
Hi All,
Having some issues with the diff lock. Im sure the diff is locking but i'm getting no light on the dash.
I have the instrument cluster out at the moment (other work going on in the dash area) but before I start stripping the cluster down to replace a ? blown bulb I need to know if it should light up when the ignition is first turned on as with other dash warning lights? Mine doesn't... Or is this normal?
Post #179486 27th Oct 2012 3:13pm
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
Hi just checked mine and on ignition no diff lock light comes on when the ignition is turned on.hope that helps a bit
Post #179488 27th Oct 2012 3:22pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
I have a light that lights up on mine on the right hand guage but to make it light upthe engine was running and i put diff lock to the left but i lifted the clutch up ( in neutral ) while holding diff lock in and it then lit up mine an 09 hope it helps
Post #179490 27th Oct 2012 3:37pm
Phoenix90
Thanks both Thumbs Up
So no need to strip the cluster down, must be an issue elsewhere. Maybe the switch on the box...
Post #179494 27th Oct 2012 3:43pm
Gwynne_90
Ive the same problem on a 2007 TDCI - How did the story end?
Post #289910 12th Dec 2013 7:09pm
jst
the sensors do fail on them simple to replace but difficult to access. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #289942 12th Dec 2013 8:41pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
The other way to check the lamp is to short the switch, it means accessing the wires into the switch which as stated before is a pain but better than starting on the console if you don't need to.
I had similar issues didn't know if I had diff lock or not I even reached the stage of replacing the switch twice!!!!I over tightened the first one and broke it.
As it turned out there was nothing wrong with the switch or lamp, but the links from the selector down to the box were seized, I even thought it was moving enough until I really tried it and discovered you can actually hear the switch engage, there's a good guide on you tube just search diff lock and follow the guide.
Hope this helps it's very satisfying to sort it out yourself lube it all up and try it out every few weeks just to keep it all moving correctly.
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #289945 12th Dec 2013 8:56pm
jst
push the diff lock lever over, jack a wheel up and see if its engaged with the light off first. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #289952 12th Dec 2013 9:10pm
