Home > Puma (Tdci) > Diff Lock Light |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 |
Hi just checked mine and on ignition no diff lock light comes on when the ignition is turned on.hope that helps a bit
27th Oct 2012 3:22pm |
speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102 |
I have a light that lights up on mine on the right hand guage but to make it light upthe engine was running and i put diff lock to the left but i lifted the clutch up ( in neutral ) while holding diff lock in and it then lit up mine an 09 hope it helps
27th Oct 2012 3:37pm |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
Thanks both
So no need to strip the cluster down, must be an issue elsewhere. Maybe the switch on the box... |
27th Oct 2012 3:43pm |
Gwynne_90 Member Since: 29 Nov 2013 Location: Southampton Posts: 15 |
Ive the same problem on a 2007 TDCI - How did the story end?
12th Dec 2013 7:09pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
the sensors do fail on them simple to replace but difficult to access. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Dec 2013 8:41pm |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 |
The other way to check the lamp is to short the switch, it means accessing the wires into the switch which as stated before is a pain but better than starting on the console if you don't need to.
I had similar issues didn't know if I had diff lock or not I even reached the stage of replacing the switch twice!!!!I over tightened the first one and broke it. As it turned out there was nothing wrong with the switch or lamp, but the links from the selector down to the box were seized, I even thought it was moving enough until I really tried it and discovered you can actually hear the switch engage, there's a good guide on you tube just search diff lock and follow the guide. Hope this helps it's very satisfying to sort it out yourself lube it all up and try it out every few weeks just to keep it all moving correctly. DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and all's where it should be!!!! Ho hum |
12th Dec 2013 8:56pm |
push the diff lock lever over, jack a wheel up and see if its engaged with the light off first. Cheers
12th Dec 2013 9:10pm |
