![]() | Home > Td5 > Immobiliser on a 2002 90? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
Td5? yes, all Td5's have the 10AS alarm unit (it's the green box behind the dash), however, not all are activated.
You'll need a nanocom,or rovacom or a friendly dealer with testbook (I see your profile is N Wilts, same as me. I suspect T.H.Whites in wootton bassett is your local dealer), pop in and offer them your amex card, they may turn it on for you. It's literally a few minutes job. with nanocom (I suspect the testbook/rovacom is the same too) you can set the immobilser to be passive etc. you'll need (if it isn't fitted) the excitor coil that fits around the ignition barrel and the plipper units to fit onto your keys so you can arm/disarm it. Also, whilst your at it, you can plug in the interior movement detector, and if you felt like it, the alarm sounder too. Last edited by diesel_jim on 23rd Jul 2009 7:24am. Edited 1 time in total |
azure111s Member Since: 19 Jul 2009 Location: North Wiltshire Posts: 55 ![]() |
Thanks Jim!
I'm buying from an independent so will get them to check that it's activated! |
No problem.
Where are you buying from? |
Jim - Have sent you a PM.
