Home > Td5 > Immobiliser on a 2002 90?
azure111s
More reconnaisance from a newby!......
Does a 2002 90 hardtop (not a County as has no rooflights; central locking; headlining to the rear, or alloys) have an immoboliser?
TIA!
Post #13277 23rd Jul 2009 6:21am
Td5? yes, all Td5's have the 10AS alarm unit (it's the green box behind the dash), however, not all are activated.
You'll need a nanocom,or rovacom or a friendly dealer with testbook (I see your profile is N Wilts, same as me. I suspect T.H.Whites in wootton bassett is your local dealer), pop in and offer them your amex card, they may turn it on for you.
It's literally a few minutes job.
with nanocom (I suspect the testbook/rovacom is the same too) you can set the immobilser to be passive etc. you'll need (if it isn't fitted) the excitor coil that fits around the ignition barrel and the plipper units to fit onto your keys so you can arm/disarm it.
Also, whilst your at it, you can plug in the interior movement detector, and if you felt like it, the alarm sounder too.
Post #13278 23rd Jul 2009 6:44am
azure111s
Thanks Jim!
I'm buying from an independent so will get them to check that it's activated!
Post #13280 23rd Jul 2009 7:18am
No problem.
Where are you buying from?
Post #13281 23rd Jul 2009 7:24am
azure111s
Jim - Have sent you a PM.
Post #13287 23rd Jul 2009 8:03am
