Home > My Defender > X tech..
Page 21 of 21 <123 ... 192021
mcma1
Thanks,
Not actually sure I am selling it, hard to replace. Smile
Yes we fitted the glass ourselves.
Post #316382 16th Mar 2014 12:18pm
K9F
Mcma1 I sent him a 'pm' suggesting as much. There is also quite a comprehensive 'how to fit' link on Landyglass website.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #316414 16th Mar 2014 2:22pm
cevapcici kid
Australia
mcma, i have a question.
I too have an x tech. i bought the jw speaker 8700 headlights as well. i nstalled them today, but i found there was two plug on the back of my original headlights, and i only one on the jw speaker lights. I plug them in and when i turn my lights on to the first setting on the light switch they dont do the dimmed lower light, but wourk like normal lights when i flick it to the 2nd setting I assume i need to somehow get that wire somehow plugged into the jw speakers. What did you do?
Post #333000 23rd May 2014 11:30am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Hi Cevapcici,
Did you buy the standard 8700 or the 8700 Evolution?
8700 (no integrated side light)
http://www.mobilecentre.co.uk/index.php?ma...cts_id=398
8700 Evolution (integrated side light)
http://www.mobilecentre.co.uk/index.php?ma...cts_id=570
The X-tech comes with headlights that feature integrated side lights instead of the completely separate side lights on the non-SVX grille. this requires the 8700 Evolution which has the integrated side light.
You can see the subtle differences in the 2 links as the evolution has a little eyebrow type slit above the first glass ball which would be the second plug and operate as a side light.
regards
Steve ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #333002 23rd May 2014 11:37am
cevapcici kid
Australia
Steve,
Thanks for the quick reply!
i bought the evolution.
Do i have to get some sort of connector that plugs each plug from the car into one plug into the headlight for the first switch setting on my headlight stick to work?
Post #333005 23rd May 2014 11:42am
Lishlandy
http://www.mobilecentre.co.uk/index.php?ma..._3_LRG.jpg
there should be a separate wire with the clear plastic covering for the 2nd side light wire as per this pic. ===================================
Steve
110 USW X-TECH
Post #333006 23rd May 2014 11:46am
cevapcici kid
Australia
mmm
there was not.
so clearly theyve sent me the wrong lights. grrrrrrrr
Post #333007 23rd May 2014 11:47am
cevapcici kid
Australia
this is the page i bought from;
in the description, are they the correct ones with the side light?
http://www.kbcarstuff.com/JW-Speaker-Model...700-ev.htm
i assumed this meant that they came with the integrated side light;
ECE RHT-compliant high/low beam with front position
ECE LHT-compliant high/low beam with front position
Post #333014 23rd May 2014 12:33pm
Lishlandy
Iv'e just checked the Speaker site so as to not suffer the wrath of opinion over knowledge (which I fully back Thumbs Up ).
The standard 8700 or on the website '8700 HB' is the type without the integrated side light.
The 8700 Evolution is with the integrated side light. From your link, they have put the standard light picture but referenced the 8700 Evolution.
You have a case to go back to them with. ===================================
Steve
110 USW X-TECH
Post #333024 23rd May 2014 1:17pm
Decca
United Kingdom 1988 Defender 90 200 Tdi HT Alaska White
Dashboard pics
Hi Mcma, do you have any other dashboard pics please? You may have answers to my thought process About what can be done/ art of the possible please? Cheers mate
Post #807212 22nd Dec 2019 9:45am
