![]() | Home > Puma (Tdci) > Defender 2.2 Tuning/Remap from IRB developments! - UPDATE!! |
What does the standard calibration give at the wheels, Ian? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
I thought the STD tune was 120 and 265?
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 841 ![]() ![]() ![]() |
Taken off LR website and I quote
"Defender’s new 2.2 litre Diesel engine produces an impressive 360Nm of torque. With 90 percent of peak power constantly on tap from as low as 2,200rpm to over 4,350rpm, it provides maximum muscle for tough working environments." Trying to find the bhp out now ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Been allover LR website and can't find a bhp fig anywhere but believe it to be 122bhp
![]() No doubt someone will correct me if I am wrong ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Does this help?
Thanks for clearing that up Jeremy.
According to an app on my iphone that means 90Nm = 120.692hp (I think that is the same as bhp) so I was nearly correct ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
Yes, Land Rover claim 120bhp and 360Nm, however this will be done under test conditions and on an engine dyno - so not in vehicle.
What did I find with a standard 2.2... at wheels: (so actual power transmitted to the road after all transmissions losses - which are typically 25% on a 4WD vehicle). Standard 2.2 Defender made 95 bhp at the wheels, and 180lbft (244Nm) in 4th gear - bearing in mind each gear has different mapping, different torque limits etc. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
More work going on today!!
Fingers crossed we can finish the new calibration prior to field trials and do the final tests on speed limiter removal. ![]() Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
vito115 Member Since: 29 Aug 2012 Location: kent Posts: 29 ![]() |
What differences makes the engine 155 horse in the Transit ?
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 ![]() ![]() ![]() |
Ian
The torque looks beautiful! ![]() I want one!! Det locker bleiben |
Engine calibration and Air Path differences... The Transit on makes 385Nm - we are getting more than that ![]() The Power Generator in a diesl engine is Air not fuel. The issue with Diesels is not how much fuel you can inject, but how well the engine can breath throughout it Rev-Range. Once we move onto stage 2 (which involves minor component/install changes), we will be making quite a bit more! Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 Last edited by Porny on 8th Oct 2012 7:42am. Edited 1 time in total |
If you have a 2.2 you can.... although, after yesterdays development time, the torque curve will be moving in the right direction! Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Pm's replied to...
All being well, the specification STG1 Calibration will be done finalised this weekend.... So not long before it will be available to the general public. This is not something I'm rushing - it needs to be 110% before it goes on sale. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
