![]() | Home > My Defender > My 90- Galvanised Rebuild |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Yes, well actually replaced the Tdi tub with a Td5 one (also without rear bulkhead) when we did the rebuild, so I already have the bigger td5 tank. However, we can't fit the Safari equip tank that goes under the wheel arch because the roll cage chassis mount in the back corner is in the way. We also put a Td5 seatbox on and the ECU and other electrics are currently under the driver's seat. Current plan is to move al that lot to behind the passenger seat, then mod the seat box so that we can fit a standard TDi tank under there. That will be a really cheap option. So that will be 65l + 45l. We want at least another 40l so we'll get a third tank custom made. There is actually quite a bit of space under a 90 but not yet decided exactly which bits to use! Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5926 ![]() ![]() ![]() |
Nicely executed. Are those pictures taken on the Rossmore estate? 1999 Defender TD5 110
Thanks, she needed the company! She's been lonely for the past 11 months ![]()
They certainly are on the Rossmore, how did you know that ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
kevb Member Since: 03 Apr 2012 Location: AllPackedUp Posts: 34 ![]() |
Lovely rebuild Gum, nice job
![]() Pam, would be interested to see how you go with the fuel tanks? one of the big downfalls with a 90 is the lack of range. |
Thanks ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Top notch
![]() I rebuilt the back of my Lotus Elise the last year, well i went to paint the wishbones and ended up with an entire strip down with sub frame out etc!! I got a little carried away ![]() |
It always seems to go like that ! I'll just do this, then this, and I may as well do this ...… And then you add up the hours that you've put into it
![]() ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Fantastic work GUM97
![]() http://www.defender2.net/forum/topic6892.html?highlight=bonatti (although I cheated and had someone else do it for me ![]() Mine was white originally.. ![]() But is now Bonatti grey.. ![]() Click image to enlarge It must be extremely satisfying to have done it all yourself Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
looking good. Not a fan of the scaffolding though.
Pom |
WarPig- It's actually Stornoway Grey, and if I'm honest, it was actually seeing the rebuild of yours that made me dedcide to do mine
pom- When you say "Scaffoliding", what do you mean? The bumper? An engine to TDi for!
I feel honoured ![]() Youve done a great job. |
Thanks WarPig, I think you went for the much easier option of having it done for you! If only I'd been so smart and thought of that before deciding to do it myself !
@Gum97
I wondered if Pom was referring to my silver roll cage in the pic I posted about my rebuild(s)- if they didn't read all the thread they might have thought mine was yours! If then then ![]() ![]() ![]() ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
