Home > Technical > Headlight height |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
normally the main beam should be set so that it is exactly horizontal. To do this find a piece of flat ground with a wall at one end. drive the vehicle up to the wall and put the lights on main an mark the centre of the beam on the wall. Reverse away for the wall at least 20m and check the height of the beam centre with the mark. Adjust as necessary. Dip beam is fixed in relationship to the main. if the main is right the dip beam will be also. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG |
7th Jul 2009 4:01am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Thanks for your help foz 2.4 90 XS
7th Jul 2009 7:13am |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
I have a diagram which shows how to set up your headlights against a wall, for left/right alignment too.
If you want it, PM me your email, & I'll send it... |
7th Jul 2009 9:09am |
pm sent 2.4 90 XS
7th Jul 2009 9:43am |
Email sent!
7th Jul 2009 9:53am |
