Home > Technical > Headlight height
Grockle
Headlight height
Morning friends,does anyone know the correct height the above should be on dipped beam,thanks. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12668 6th Jul 2009 8:28am
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
normally the main beam should be set so that it is exactly horizontal. To do this find a piece of flat ground with a wall at one end. drive the vehicle up to the wall and put the lights on main an mark the centre of the beam on the wall. Reverse away for the wall at least 20m and check the height of the beam centre with the mark. Adjust as necessary. Dip beam is fixed in relationship to the main. if the main is right the dip beam will be also. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #12720 7th Jul 2009 5:01am
Grockle
Thanks for your help foz Thumbs Up 2.4 90 XS
Post #12721 7th Jul 2009 8:13am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I have a diagram which shows how to set up your headlights against a wall, for left/right alignment too.
If you want it, PM me your email, & I'll send it...
Post #12727 7th Jul 2009 10:09am
Grockle
pm sent Thumbs Up 2.4 90 XS
Post #12728 7th Jul 2009 10:43am
Ads90
Email sent!
Post #12729 7th Jul 2009 10:53am
