Home > Maintenance & Modifications > Cleaning Chequer Plate
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
I have cheque plate on the bonnet and wings. Always said I would not bother but was persuaded in to it in the end to aid getting to storage on the roof rack when camping. It's now been on for the past three years, it's the anodised plate but is starting to look a bit grubby. I have pressure washed it and used brushes of various stiffness but can't get the black grime off around the raised chequer bits.
Any suggestions on what to use be it chemical or mechanical to clean up the plate without scratching or damaging the anodising ? 2007 TD5 90 Hard Top
Post #166650 6th Sep 2012 6:26am
jst
petrol? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #166652 6th Sep 2012 6:28am
I've heard that pan cleaning sponges (the slightly abrasive plastic ones, so they won't actually scratch the ali, not like the wire wool type stuff) work well.
Don't know what chemical to use though. maybe jif? (or cif, if you've got a lithp Laughing )
Post #166653 6th Sep 2012 6:33am
JWL
When I gave mine a bit of a clean to spray it black I used some kitchen surface cleaner, to the eye it did the job very well, needed a bit of work with a decent stiff bristled brush to work it into all the nooks and crannies though!
Post #166654 6th Sep 2012 6:59am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I uesd to have a series two fire appliance which had quite a bit of chequer plate on it. When I spoke to folks at shows with full size fire engines, quite a few of them recommended using 'brown sauce' (yes really) as a cleaning agent!
This is for untreated chequer plate of course, and annodized stuff may react in a different way. Euro-Leafing to infinity and beyond.....
Post #166683 6th Sep 2012 11:49am
WD-40? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #166692 6th Sep 2012 12:44pm
MartinK
Someone on here a while back said he used wheel cleaner (i.e. wonder-wheels type stuff) to good effect.
Not sure I would want that all over the paintwork tho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #166696 6th Sep 2012 1:05pm
Landlord
Thats the issue with chemicals, dont want to damage paintwork.
The grime is the stubborn stuff at the bottom of the raised chequer bits which are hard to remove with a brush. Might try some wheel cleaner carefully on it ! 2007 TD5 90 Hard Top
Post #166749 6th Sep 2012 4:31pm
MartinK
Found the thread:
http://www.defender2.net/forum/topic8437.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #166755 6th Sep 2012 4:50pm
fekete
jst wrote:
petrol?
Thumbs Up the only thing that work properly NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #166767 6th Sep 2012 5:14pm
Likeomg
can't it just be removed for cleaning? that way you can use chemicals you wouldn't normally want near the paintwork
Post #166934 7th Sep 2012 6:15pm
Yetiman
Try Britemax metal polish. Top stuff and not too pricey. I wouldn't lather it all over the paintwork but if any goes on it, just wipe off quickly and you'll be fine. If it's really grubby, some fine wire wool combined with the polish will soon sort it. They also do a sealer for metal that will protect it from dulling again in the future.
Cheers Thumbs Up She's not old...just older
Post #166953 7th Sep 2012 9:49pm
Yetiman
Post #166954 7th Sep 2012 9:49pm
110SEB
How about Coca Cola. We all know what it does to dirty coins.
Post #166961 8th Sep 2012 5:52am
rustandoil
Alloy wheel cleaner worked in with a brass wire brush worked a treat on mine Thumbs Up
Post #166970 8th Sep 2012 7:00am
