![]() | Home > Maintenance & Modifications > Cleaning Chequer Plate |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
petrol? Cheers
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I've heard that pan cleaning sponges (the slightly abrasive plastic ones, so they won't actually scratch the ali, not like the wire wool type stuff) work well.
Don't know what chemical to use though. maybe jif? (or cif, if you've got a lithp ![]() |
When I gave mine a bit of a clean to spray it black I used some kitchen surface cleaner, to the eye it did the job very well, needed a bit of work with a decent stiff bristled brush to work it into all the nooks and crannies though!
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1385 ![]() ![]() ![]() |
I uesd to have a series two fire appliance which had quite a bit of chequer plate on it. When I spoke to folks at shows with full size fire engines, quite a few of them recommended using 'brown sauce' (yes really) as a cleaning agent!
This is for untreated chequer plate of course, and annodized stuff may react in a different way. Euro-Leafing to infinity and beyond..... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
WD-40? Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Someone on here a while back said he used wheel cleaner (i.e. wonder-wheels type stuff) to good effect.
Not sure I would want that all over the paintwork tho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Thats the issue with chemicals, dont want to damage paintwork. The grime is the stubborn stuff at the bottom of the raised chequer bits which are hard to remove with a brush. Might try some wheel cleaner carefully on it ! 2007 TD5 90 Hard Top |
Found the thread:
http://www.defender2.net/forum/topic8437.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
can't it just be removed for cleaning? that way you can use chemicals you wouldn't normally want near the paintwork
Yetiman Member Since: 13 Aug 2010 Location: London Posts: 138 ![]() ![]() |
Try Britemax metal polish. Top stuff and not too pricey. I wouldn't lather it all over the paintwork but if any goes on it, just wipe off quickly and you'll be fine. If it's really grubby, some fine wire wool combined with the polish will soon sort it. They also do a sealer for metal that will protect it from dulling again in the future.
Cheers ![]() |
Cheers ![]() |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
How about Coca Cola. We all know what it does to dirty coins. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 782 ![]() ![]() ![]() |
Alloy wheel cleaner worked in with a brass wire brush worked a treat on mine
