Home > Maintenance & Modifications > Cleaning Chequer Plate |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
petrol? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Sep 2012 6:28am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I've heard that pan cleaning sponges (the slightly abrasive plastic ones, so they won't actually scratch the ali, not like the wire wool type stuff) work well.
Don't know what chemical to use though. maybe jif? (or cif, if you've got a lithp ) |
6th Sep 2012 6:33am |
When I gave mine a bit of a clean to spray it black I used some kitchen surface cleaner, to the eye it did the job very well, needed a bit of work with a decent stiff bristled brush to work it into all the nooks and crannies though!
6th Sep 2012 6:59am |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1380 |
I uesd to have a series two fire appliance which had quite a bit of chequer plate on it. When I spoke to folks at shows with full size fire engines, quite a few of them recommended using 'brown sauce' (yes really) as a cleaning agent!
This is for untreated chequer plate of course, and annodized stuff may react in a different way. Euro-Leafing to infinity and beyond..... |
6th Sep 2012 11:49am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20324 |
WD-40? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
6th Sep 2012 12:44pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Someone on here a while back said he used wheel cleaner (i.e. wonder-wheels type stuff) to good effect.
Not sure I would want that all over the paintwork tho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
6th Sep 2012 1:05pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Thats the issue with chemicals, dont want to damage paintwork. The grime is the stubborn stuff at the bottom of the raised chequer bits which are hard to remove with a brush. Might try some wheel cleaner carefully on it ! 2007 TD5 90 Hard Top |
6th Sep 2012 4:31pm |
Found the thread:
http://www.defender2.net/forum/topic8437.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
6th Sep 2012 4:50pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
the only thing that work properly NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
6th Sep 2012 5:14pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
can't it just be removed for cleaning? that way you can use chemicals you wouldn't normally want near the paintwork
7th Sep 2012 6:15pm |
Yetiman Member Since: 13 Aug 2010 Location: London Posts: 138 |
Try Britemax metal polish. Top stuff and not too pricey. I wouldn't lather it all over the paintwork but if any goes on it, just wipe off quickly and you'll be fine. If it's really grubby, some fine wire wool combined with the polish will soon sort it. They also do a sealer for metal that will protect it from dulling again in the future.
Cheers She's not old...just older |
7th Sep 2012 9:49pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
How about Coca Cola. We all know what it does to dirty coins. |
8th Sep 2012 5:52am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
Alloy wheel cleaner worked in with a brass wire brush worked a treat on mine
8th Sep 2012 7:00am |
