Home > Technical > THE webasto Thread
Page 6 of 16 <123 ... 567 ... 141516>
dgardel
Italy
[quote="jst"]
dgardel wrote:
T1G UP wrote:
Looking at this picture.
Could you not add the webasto water pipes by plumbing it in series with the pipe that run from No 1 to 'to heater valve' text? but add it before the T piece?
would there not be coolant flowing in there the whole time the engine was running regardless of the heater position? rather than between the T and the heater valve where flow rate is determined by the heater position?
i presume the coolant is running Right to left? ie out the back of the block to the top of the rad?
Plumbing the Webasto like your description, you will lose part of the heat, that you can use into the cabin heater, because you drive the water to the cabin heater AND the EGR gas exchanger....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #174260 9th Oct 2012 7:56am
jst
Which way does that water flow? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #174265 9th Oct 2012 8:11am
jst
twin pickup in Puma 110 tank
in the end i decided to do this rather than use one pickup to feed two webastos so as not to have the potential problem of a lack of fuel supply issue. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #175464 13th Oct 2012 7:18pm
jst
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #175466 13th Oct 2012 7:18pm
T1G UP
still waiting for my parts. hopefully be here for me next weekend
Post #175480 13th Oct 2012 7:38pm
jst
presumably you could plumb into the heater vale return pipe instead of the input pipe thus heating the engine block first then the heater matrix?, Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176697 17th Oct 2012 9:20pm
don't see any reason why not, but on a puma, the hot/cold adjuster actually adjusts the flow of coolant through the internal heater rad
Post #176720 18th Oct 2012 6:19am
jst
agreed, the point being it will heat the engine first and then the heater matrix assuming the heater temp knob is turned off cold
rather than the heater matrix first Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176726 18th Oct 2012 6:39am
just to be clear, it probably does not matter which side of the matrix pipes you fit the feed, if the knob is set to blue, the inside will not get warm
Post #176730 18th Oct 2012 6:51am
jst
^^ thats my understanding too. i dont want the inside warm, i just want an engine pre warmer. but as i understand it if its plumbed into the the actual heater valvle block if the heater is off (ie on cold) then the coolant wont flow through the webasto?
i intend to fit it between the egr return and the return from to the engine.
ie between the T piece that goes to the engine coming from the heater, and egr return, that way the webasto will have flow regardless of what the heater valve is on. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176754 18th Oct 2012 8:14am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Was about to post something similar. If you install on the input or output of the heater matrix you would have no flow when the heater is set to cold.
Don't know where the thermostat valve is on the Puma but it may also restrict flow through the engine until the coolant reaches a predefined temperature on the engine side of the thermostat. Where you plan on installing the webasto does it have continuous flow regardless of the thermostat ? 2007 TD5 90 Hard Top
Post #176782 18th Oct 2012 10:25am
no, the pipe to the heater is a 3 way....
1. into the flow controller (the hot/cold knob)
2. out from the matrix
3. out from the matrix by-pass
so, with the heater on cold the water will by pass the matrix and flow straight back out via the return pipe
have a closer look at DG's pics..
On my 2010 puma, i have plumbed into the "in" flow into the matrix and when set to blue the water bypasses the matrix
James - give me a call if you'd like to discuss
Post #176783 18th Oct 2012 10:36am
jst
cheers BP man, didnt know that, so it makes little odds which pipes are used then.
may well go with the outlet of the heater valve still as it would then go direct to the engine first, plus there is a bleed screw at the top of the pipe, lastly its where LR install them from what i have seen. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176880 18th Oct 2012 6:31pm
jst
with luck tomorrow it will go in Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176954 18th Oct 2012 8:59pm
good luck tomorrow James !
Post #177111 19th Oct 2012 1:15pm
