Home > Technical > THE webasto Thread |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6632 |
It's the Webasto Thermo Test software but I'm not 100% happy now so I'll hold off on the how-to 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Jan 2019 12:01pm |
https://www.ebay.co.uk/itm/Analog-to-W-bus...2776404068 I've not used one myself but guys on DISCO3 have. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Jan 2019 12:13pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
Ideal thanks Martin 2002 90 Td5 Station Wagon
24th Jan 2019 12:17pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
so I've fitted a cab heater which is just connected to my battery, question is do i need to fit an additional leisure battery?
Greg |
28th Jan 2019 6:17pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Depends on how long you plan to run it for? If you're thinking of running it constantly during the night as the outside temps are -20 outside, then i'd probably consider it.
If it's a back up to the standard heater and you're not going to run it for long periods ( think 5-6 hours ) without the engine running, then i reckon you'll be just fine |
28th Jan 2019 7:01pm |
It’s when I leave it in the feilds, so only for 30mins to 2hrs. I might try it for long sessions on the drive. So if it won’t fire the engine after at least I’m not stranded
28th Jan 2019 8:30pm |
You should be fine, but a test is a good idea
The main draw is on fire up, once the unit hits temp ( about a minute ) then the power draw drops drastically. Turning it on for a few minutes whilst the engine is running wouldn’t be a bad idea |
29th Jan 2019 8:14am |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
It was an ideal Oc outside this morning so I thought it would be an excellent time to catch some data around coolant temperature with the Webasto only - Here is a 30 minute warm up with the Defender set to max fans and hot first thing this morning.
Thermotop C wired in series just before the heater Matrix, so naturally, the heater output seems to be good enough to defrost etc. within minutes. Click image to enlarge |
1st Feb 2019 9:28am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Trying to sort out a remote for my Airtop ST2000, I spoke to several people and even a Webasto technitian. They all said that the T91 kit would work. I can confirm that it doesn't, I've tried all variations so I've pulled the T91 kit out and now sourcing another option.
I was under the impression that the Thermocall was only for newer models? Has anyone found a cheaper version of remote control? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
1st Feb 2019 5:33pm |
How is your AirTop normally switched on?
Which Telestart kit do you have? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Feb 2019 6:19pm |
Martin, I only have the rheostat to turn it on. Which means trudging down the garden to turn it on. Would rather just sit in bed and turn it on.
Don't have a telestart kit, The T91 is an RF unit from what I gather. Which is now surplus to requirements so will appear for sale very soon 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
1st Feb 2019 6:23pm |
T91 is Telestart
Got a photo of your T91 kit? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Feb 2019 6:28pm |
Ah, my mistake. I'll get a photo shortly 110 D250 SE HT
1st Feb 2019 6:32pm |
Pics as promised
Label on control unit Click image to enlarge Remote Click image to enlarge General Box Pic Click image to enlarge Box label 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
1st Feb 2019 6:57pm |
