Home > In Car Electronics > The definitive Defender ICE thread
Page 6 of 71 <123 ... 567 ... 697071>
Thanks Buzzsaw Wink It sounds like it too believe me Shocked
No doubt mr. Killer 90 will do a good job too Smile
*Edit*
I like those tweeters Chris! Cool WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #170003 22nd Sep 2012 7:51pm
Killer90
Site Sponsor
Thumbs Up cheers steve, they fit lovely, i want to extend the wires now and perhaps stick the two way converters behind the cubby Cool CSK Automotive
www.cskautomotive.co.uk
Post #170006 22nd Sep 2012 8:04pm
You'll be surprised how much room there is with a 90HT for things like that with a bit of imagination. Plenty of cavitys behind the dash ect too. Just being careful not to place anything or any wires where it will interfere with any controls or OE equipment. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #170012 22nd Sep 2012 8:14pm
ickle
DAB
Has anyone fitted a DAB radio & if so what aerial did you use and where did you fit it?
Thanks Keith
Post #172521 1st Oct 2012 7:40pm
I've just ordered the following from 'JustKenwood' following recommendations from folk on here, I'll report back once installed Thumbs Up
Kenwood KFC-E1052 speakers
Kenwood KSC-SW01 active subwoofer
Parrot Asteroid Bluetooth head unit
Post #172655 2nd Oct 2012 11:46am
I highly doubt you'll be disappointed Thumbs Up Smile WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #172660 2nd Oct 2012 1:17pm
kinchjet
2012 Defender 90 Puma 2.2 HT Blenheim Silver
2012 Dfender 90
Anyone know the best place to connect the power lead(yellow) for a kenwood KSC-SW01 Subwoofer
The install booklet shows picking power off the fuse box but looking at the under seat box its not clear where to pick up from
Crying or Very sad
Paul
Post #176607 17th Oct 2012 7:54pm
mk1collector
I don't want to sound rude but if you can't pick out a live in a fuse box you should let a professional do the job as it could be a fire hazard
Post #176613 17th Oct 2012 8:01pm
Do you mean the live feed directly to the amp? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #176626 17th Oct 2012 8:21pm
And as the post by mk1 you really do have to be careful what you are doing as incorrectly fused electrical work done can be a massive fire hazard if a short occurs. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #176627 17th Oct 2012 8:23pm
kinchjet
Yes its the main power feed and its fused downstream.
Im more than qaulified to work it out as have spent 30 years as chief engineer on business Jet aircraft not to metion some suprsonic cold war jet rebuilds
just wanted to save time as thought someone here would have done it before.
Confused
Post #176647 17th Oct 2012 9:11pm
I'm looking for some ideas. I bought a focal i20 integrated sub, it's up and running in the 110 and sounds great (well compared to how it used to sound).
It's not big but not small (details here: http://www.focal.com/files/ibus20-specification-sheet2.pdf)
Height: 71.5mm (2.8”)
Length: 344mm (13.5”)
Width: 250mm (9,8”)
so I plan to fit under middle row seats but here's the question ... how you you get the wires from the head unit to the sub ? Inside or outside/under ? currently I'm thinking run it down the back of the dash then putting it in black convoluted trunking and running next to the seats, under the rubber middle row floor mats and up to the sub.. any other ideas ?
Post #176651 17th Oct 2012 9:15pm
Confused
If it's the live feed you need and not ignition then I would take it direct from the battery. You'll also need the appropriate Amperage rating fuse as close to the 12v source (battery Positive +) if you don't do this the cable between the battery and the amp is fully UN-protected and is a big no no IMHO and a fire risk. Sorry I cannot give any more detail myself as I don't have the same sub as you do but there are members on here that do. Thumbs Up Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #176656 17th Oct 2012 9:18pm
bpman wrote:
So I plan to fit under middle row seats but here's the question ... how do you get the wires from the head unit to the sub ? Inside or outside/under ? currently I'm thinking run it down the back of the dash then putting it in black convoluted trunking and running next to the seats, under the rubber middle row floor mats and up to the sub.. any other ideas ?
Personally I would with your wires forget the convoluted tubing because it will be not flexible enough and add to the bulk of it. I would instead spiral wrap it in electrical tape this way it keeps flexible and keeps the diameter small and also some protection too. For routing I would follow along the gearbox tunnel drivers side and follow along through the middle just to the left of the seat runner on the drivers seat. might be easier if you take the seat out too just for easier access. Give me a shout if you'd like any other ideas. Smile
*EDIT* forgot to mention I would go under the mat / carpet too. Mine has rubber the harder material to manipulate but it's possible with rubber and carpet. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #176664 17th Oct 2012 9:23pm
thanks Steve ... no magic route Sad I'll have another look in the light
Post #176665 17th Oct 2012 9:24pm
