- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
![](templates/vbnew/images/breadcrumblogo.gif) |
Home > Td5 > MAF Flow Rates/Frequency |
me@td5.org
![](templates/vbnew/images/spacer.gif)
wslr wrote:Testbook will show a healthy air flow sensor as 55 to 60 kg/hr at idle with no loads on the electrics, and 190 to 200 at 2000 rpm. I can't remember the tests off the vehicle - you'll have to check TOPIx.
Thanks, I've never used TOPIx but I'll give I a go. It's frustrating because all of the Bosch sensors have proper data sheets but there is no good data I can find on the VDO sensors.
P
26th Aug 2012 8:03pm |
wslr
If it helps, a new Genuine Part sensor and new VDO sensor read exactly the same with no difference in live data readings.
26th Aug 2012 8:10pm |
