Home > Td5 > MAF Flow Rates/Frequency
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Does anyone know the expected flow rates on the TD5 MAF sensor and the associated output frequencies?
Post #164530 26th Aug 2012 5:15pm
wslr
Testbook will show a healthy air flow sensor as 55 to 60 kg/hr at idle with no loads on the electrics, and 190 to 200 at 2000 rpm. I can't remember the tests off the vehicle - you'll have to check TOPIx.
Post #164546 26th Aug 2012 6:58pm
me@td5.org
Thanks, I've never used TOPIx but I'll give I a go. It's frustrating because all of the Bosch sensors have proper data sheets but there is no good data I can find on the VDO sensors.
P
Post #164599 26th Aug 2012 9:03pm
wslr
Confused
If it helps, a new Genuine Part sensor and new VDO sensor read exactly the same with no difference in live data readings.
Post #164602 26th Aug 2012 9:10pm
