Home > Td5 > MAF Flow Rates/Frequency |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Testbook will show a healthy air flow sensor as 55 to 60 kg/hr at idle with no loads on the electrics, and 190 to 200 at 2000 rpm. I can't remember the tests off the vehicle - you'll have to check TOPIx.
26th Aug 2012 5:58pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
Thanks, I've never used TOPIx but I'll give I a go. It's frustrating because all of the Bosch sensors have proper data sheets but there is no good data I can find on the VDO sensors. P |
26th Aug 2012 8:03pm |
If it helps, a new Genuine Part sensor and new VDO sensor read exactly the same with no difference in live data readings. |
26th Aug 2012 8:10pm |
