Home > Puma (Tdci) > Puma gearbox |
PumaGreg Member Since: 04 Mar 2009 Location: UK Posts: 80 |
It's not something so simple as the handbrake shoes in the transmission drum dragging slightly, is it? Greg
Currently: 2013 90 2.2 Puma Base Station Wagon 1991 90 Tdi 2015 Discovery Sport 2.2 |
24th Jun 2009 12:27pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
By looking at the MC, it should be a new version Puma 110" SW
24th Jun 2009 1:48pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
I still think it is... just because I used to have this problem, but I don't any more! (And I've made no adjustments etc). It just went away, like maybe a high-spot wears away. I can't think a gearbox issue would 'get better' after cooling, but a brake (or clutch) issue might? |
24th Jun 2009 3:22pm |
I have no clonks when the whole thing is cold. After getting warmer i get clonks when shifting from 4th-5th-6th. Puma 110" SW
24th Jun 2009 3:35pm |
silverpig Member Since: 16 Nov 2008 Location: York Posts: 6 |
MK Mine is exact same as yours. |
24th Jun 2009 5:07pm |
austen Member Since: 10 Mar 2008 Location: Sydney Posts: 52 |
It is the handbrake and the fix is simple. Screw the drum adjuster in all the way and then slacken off 2 turns. Next shorten the outer cable by about 5mm. The adjusting nuts are on the other end of the cable where it comes out of the seatbox and can be reached from underbeath. Screw inwards so there is 5mm less thread visible.
Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
25th Jun 2009 12:11am |
