Home > Puma (Tdci) > Puma gearbox
bustduster
Puma gearbox
Seem to recall some gearboxes have been replaced over the past two years. Does anyone know if they were replaced with the same version or an upgraded one? Reason I'm asking is that I have just had clutch, flywheel, brake drum and shoes replaced under warranty to try and resolve the known knocking/clanking problem when coming to a halt after a longish trip (around two hours). Dealer had several attempts to solve it and although replaced clutch has improved driveability in traffic it hasn't solved the main ongoing problem. Just completed another longish trip and after exiting motorway the problem is still there and it is proving difficult to then drive around in stop/start traffic until it has cooled down for a while. Any comments would be welcome.
Post #12295 24th Jun 2009 10:54am
PumaGreg
United Kingdom 2013 Defender 90 Puma 2.2 SW Tamar Blue
It's not something so simple as the handbrake shoes in the transmission drum dragging slightly, is it? Greg
Currently:
2013 90 2.2 Puma Base Station Wagon
1991 90 Tdi
2015 Discovery Sport 2.2
Post #12297 24th Jun 2009 12:27pm
MK
By looking at the MC, it should be a new version Puma 110" SW
Post #12300 24th Jun 2009 1:48pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I still think it is... just because I used to have this problem, but I don't any more!
(And I've made no adjustments etc).
It just went away, like maybe a high-spot wears away.
I can't think a gearbox issue would 'get better' after cooling, but a brake (or clutch) issue might?
Post #12306 24th Jun 2009 3:22pm
MK
I have no clonks when the whole thing is cold. After getting warmer i get clonks when shifting from 4th-5th-6th. Puma 110" SW
Post #12307 24th Jun 2009 3:35pm
silverpig
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
MK Mine is exact same as yours.
Post #12308 24th Jun 2009 5:07pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
It is the handbrake and the fix is simple. Screw the drum adjuster in all the way and then slacken off 2 turns. Next shorten the outer cable by about 5mm. The adjusting nuts are on the other end of the cable where it comes out of the seatbox and can be reached from underbeath. Screw inwards so there is 5mm less thread visible.
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #12314 25th Jun 2009 12:11am
