Home > Puma (Tdci) > Bang, crash, wallop.....
Page 2 of 2 <12
schuee
Thank you all for putting my mind to rest, mine makes the noise like a steel tray being dropped underneath at the rear over bumps and I was slightly worried, now I will mention it to my dealer when next in for a service, is this something they will look at under warranty? or mod to stop it from happening
Post #164404 25th Aug 2012 10:15pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
schuee wrote:
...mine makes the noise like a steel tray being dropped underneath at the rear over bumps......
That's the perfect description....and I still have it after removing the rear brakes and replacing the pins and springs on them. Also a healthy smear of copper grease applied. They were pretty well in place and doubted they were the cause of the noise even before carrying out the above...
...any other ideas folks? Cheers,
Superspoons
Post #164802 27th Aug 2012 9:55pm
AndyS
Long shot, the cover the over the fuel filter makes a noise like you describe. Take it off, see what happens.
Post #164811 27th Aug 2012 10:15pm
superspoons
Thumbs Up That's a good call. Will check it. Cheers,
Superspoons
Post #164812 27th Aug 2012 10:23pm
spudfan
Ireland
If you have an adjustable tow hitch take off the bracket with the towball. When I did this the noise stopped and with the bracket for the towball refitted the noise returned. I jammed in some old wiper blade rubber between the braket and slider plate and have had no noise since. Worth a try. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #164814 27th Aug 2012 10:54pm
superspoons
OK, this is driving me mad now. I have OCD trying to find this....I've crawled all under at prodded/pushed/pulled/twisted everything that could possible move and can't find a thing loose. Fuel filter cover was tight as could be.
So took it down a road with speed bumps.....crash/bang/wallop.....did the same the other way with brakes lightly applied ..no noise. How can these be! The pads are rock solid in the calipers... retaining bars/springs solid too.
I am mystified...and Censored Censored off Cheers,
Superspoons
Post #167006 8th Sep 2012 1:29pm
ericvv
So it must have something to do with the brakes....
I have the same issue as you all when driving on uneven roads, but mine goes to the dealer monday for the annual service. I told them about this crash, bang, wallop, and asked them to look for what it is, told them I suspect the rear break shoes.... We will see. Will let you know. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #167014 8th Sep 2012 3:27pm
dgardel
Italy
Check the disk brake screens Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #167015 8th Sep 2012 3:31pm
superspoons
Yep, done that, one of the first things I looked at. Wondered of they were loose/broken. Usually take them off anyway but in my case all was good. Cheers,
Superspoons
Post #167016 8th Sep 2012 3:44pm
Noticed the pins look like they can move a fair bit and could be causing noise. However, if it's the pads moving then you could try some of the buffer pads that fit at the end of the calipers.
Post #208114 3rd Feb 2013 9:18pm
Page 2 of 2 <12
