Home > My Defender > Webasto Block Heater Photos |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8149 |
good pictures.
LHD? i am looking to do one of these, where/who did you get the unit from? was just the fitting kit from Switz or the whole lot? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2012 8:50am |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
We can supply and fit LHD or RHD Wesbasto kits if you struggle
6th Aug 2012 8:58am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
OT: 5 cylinder engine? I thought the TDCi were a 4 pot engine? 1999 Defender TD5 110
6th Aug 2012 9:05am |
they are 4 pot. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2012 9:12am |
the webasto units are not left or right handed, but because mine is a LHD, I bought a fitting kit from Webasto Switzerland, I will be kicking myself if Tim at MobileCentre can get them
The units vary from £850 - £1100 depending on how nice the dealer is, and the unit comes with prettty much all you need for a standard installation, however I used the Swiss kit because it keeps the unit up out of harms way, easy to service etc. The additional installation kit was about £200. I was told the kits come with the timer unit but mine did not .. so I opted for the square one because I think it looks better on the dash. I also opted to remove the fuel tank and install a seperate feed direct from the tank rather than "T" ing into the fuel pipes. I also opted for the one-way valve as recommended by Daniele All in, with my basic mechanical and electrical skills has taken about 3 days to install and test. @Tim - if you need any info on the kit just drop me a PM but they are LHD only so I would imaging a low demand |
6th Aug 2012 9:36am |
cheers BPman.
LHD bit was aimed at the veh rather than the install. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2012 9:48am |
We are a direct Webasto dealer so can get the LHD & RHD fitting kits. As you say the thermo top C is universal. We fit ours under the wing using some custom brackets so it is out of the way.
When we fit one it is a full (LONG) days job to do it with two people on most of it. |
6th Aug 2012 9:54am |
I counted 5 injector pipes, or is one a return? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th Aug 2012 12:09pm |
deep down Member Since: 02 May 2012 Location: France Posts: 204 |
The middle one, is the fuel rail high pressure supply line I believe. |
6th Aug 2012 12:47pm |
What kind of heating system is this? To preheat the interior passenger compartment, or to preheat the engine coolant prior to winter cold starting? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
6th Aug 2012 5:09pm |
it does both Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2012 5:27pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
For such good work, take the rest of the week off Russell 2011MY 110 XS USW Black |
6th Aug 2012 6:34pm |
Very good job BPMAN!!!
this is mine Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 6th Aug 2012 7:42pm. Edited 1 time in total |
6th Aug 2012 7:11pm |
remind me again why you need the one way valve? Cheers
6th Aug 2012 8:31pm |
