Home > My Defender > Webasto Block Heater Photos
Page 3 of 4 <1234>
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Good observations. However, I thought that the temperature control on the interior heater in a Defender directly altered the flow of hot water into the heater matrix. Therefore, installed as BP has, with the temperature control turned to minimum surely only the engine will be heated?
Pete
Post #160942 9th Aug 2012 12:47pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
XS Pete
Your are right IF the temp control valve is a 2 way valve so it doesn't stop the flow if set on cold of the right hand side circuit in the diagram.
As pictured in the diagram it looks as if the valve would close off/regulate the complete flow through the heater matrix.
I am not sure but i think the valve on the puma is a 2 way valve, so basically the heater is installed in parallel with the heater matrix.
Will peek under the bonnet tonight to confirm this.
Thumbs Up
Post #160945 9th Aug 2012 12:54pm
dgardel
Italy
XS, Tatra
the Webasto installation is depending from the car water circuit and it should change car by car.
The Defender cabin heater valve is a 3 way valve that means:
1. knob on BLUE - COLD: 100% of the water go through the valve directly to the engine block (0% to the cabin heater) 3 --> 4
2. knob on RED - WARM: 100% of the water go through the valve directly to the cabin heater (and then to the engine block) 3 --> 2 --> 1 --> 4
Remember that the cabin heater pipeline carry only a part of the total flux of the cooling circuit
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160949 9th Aug 2012 1:18pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Re heating Cabin or Engine
My Thermotop C ( fitted without a one way valve) heats the engine up first.
It is only when the coolant temperature is warm enough - 48C I think - that the heater fan comes on to warm the cabin - I thought this was standard.
The cabin heater controls are set to Warm with the fan set to max, after about 30 mins of heating the engine the fan comes on.
I did not install the timer or remote - so I simply turned the webasto on as we woke in the morning, as we broke camp the engine was pre heated and the truck cab was warmed ( not hot as only a Td5 ).
This worked very well in Norway last year and the engine allways started easily.
I only needed to use the webasto whilst driving to maintain engine temp when it dropped down below minus 40C.
Post #160950 9th Aug 2012 1:29pm
dgardel
Italy
tatra805 wrote:
BPMan,
Most cars are done that way. But i found that at outside temps of -10 the cabin will take so much heat that the engine barely heats up. My 3.0 liter MB takes 1.5 hours to get to 40° water temp while the cabin is defrosted within 20 minutes.
It is not the Defender case: I tested. -22°C outside temp, water temp was 68°C after 30 mins of webasto operation (Defender engine OFF) with 15°C inside the cabin (mine is a 90 not a 110)
Remember that the Webasto ECU switch on the cabin fan only when the engine water reaches 48 °C
You will also notice that once you start the car you will momentary cool down the interior while the engine heats up and thermostat opens.
Thats normal, I repeat with the webasto you carry only a little part of the water. Switched on the engine you move all the water mass but mine cool down only 5 - 6 °C
That’s another problem i experienced here as the engine would cool down from 40° and never reach normal operating temps when starting driving, the cooling capacity of the engine outperformed the webasto heater and eventually also the cabin started cooling down.
I installed the webasto parallel to the heater matrix (so from pt2 vertical down to the return line).
With the 3 way valve you have the same putting the cabin temp knob in the half
I found that this was a better protection for my engine, as the engine block would not cool down again. And even gave better cabin conditions although you don’t step into a 30° cabin when driving off.
I agree but in the case of the Defender the dgardel - Outback Engineering & BPman solutions works 100% perfectly!!!
Smile
If you want the 100% efficiency on engine heater operation it is sufficient to left the knob on BLUE.
But I tested well my solution (my father in love lives on the Alps and during the winter is normally to go less that -20 °C (less than -4 °F) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160951 9th Aug 2012 1:32pm
dgardel
Italy
Agree, the webasto is a "nice to have" into this conditions...........
other than a very good winter diesel.
Have you a heater on the fuel filter? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160952 9th Aug 2012 1:39pm
boode
Have you a heater on the fuel filter?[/quote]
No other pre heaters - just the webasto - also only a 4.2Kw but it worked well.
The TDCis needed breather pipe heaters, my Td5 did not.
Post #160954 9th Aug 2012 1:47pm
Thanks all for your posts, especially the notes on the one way valve, I believe this is a good upgrade
My main reason for installing is to protect the engine on my forthcoming trip to nordkapp where -20/-40 temperatures can be expected
As Daniele shows it is possible to bypass the cabin heater radiator and when required this Is a perfect option for a tdci
I've also found a remote control kit so expect install photos soon
I am also fitting an air top cabin heater photos to follow - but not in a defender Shocked
(Marcus - before you say it, no not in my other tdci)
Post #160976 9th Aug 2012 4:59pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Lets hope that all works nicely for you BPMan Thumbs Up
Failing that I have some nice warm socks and a jumper you could borrow for your trip Very Happy
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #160984 9th Aug 2012 5:27pm
tatra805
Thanks for all the explanation and first hand experiences, seems my worries are not necessary in this case. Thumbs Up
Like this forum. Bow down
Post #161009 9th Aug 2012 7:41pm
I bought an eberspacher d2 from the bay, 12 months old and less than 1/2 price ... happy days. I built a test rig this afternoon and have been testing it, started first time. Waiting for housing to be made now, pics to follow.
Tested my coleman lantern today, works fine, mantels are quite delicate Whistle (Good job I bought 16 spares)
Post #162918 18th Aug 2012 5:11pm
T1G UP
for the roof tent....not the fesser?!
i've got my eye on a webasto for mine.
there are v, p, c, ,e z, and evo 4, evo 5 and evo 5+!
so i got my eye on a cheapway of doing this
Post #164402 25th Aug 2012 9:02pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Swear by a Vapalux. Great paraffin lamp, have used for years but like bpman i carry a load of spare mantels.
A good condition lamp is hard to find but have just found this on eBay
http://www.ebay.co.uk/itm/Vapalux-Hurrican...2949wt_982
Worth grabbing one whilst you can. Give off 1 kw of heat and are a lovely comfy light when camping. 2007 TD5 90 Hard Top
Post #164408 25th Aug 2012 9:40pm
good find landlord ... have you tried these lamps in extreme cold weather, I guess with Nordic additives they won't wax ?
Post #164413 25th Aug 2012 10:08pm
Landlord
Not extreme cold weather but they are MOD kit.
I take mine every where and has worked well. Spares are still available and mantels are interchangeable with Tilley lamps. Tried Tilley lamps, there ok but the Vapalux are much better.
Have not tried Coleman lamps, presume theyre just as good..
Apologise for hijacking thread Exclamation 2007 TD5 90 Hard Top
Post #164414 25th Aug 2012 10:17pm
Page 3 of 4 <1234>
