Home > My Defender > Webasto Block Heater Photos
Page 1 of 4 1234>
just finished installing the webasto block heater, a couple of photos ...
I used a one-way valve as advised by dgardel
I bought a webasto kit from Webasto Switzerland, it mounts the unit above the exhaust manufold heat shield
Controller/Timer mounted inside
can hardly see it ...
.. powered up and worked first time (well once the diesel had pumped through)
just need to get a t91 remote for it ...
Post #160249 6th Aug 2012 7:56am
jst
good pictures.
LHD?
i am looking to do one of these, where/who did you get the unit from? was just the fitting kit from Switz or the whole lot? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160267 6th Aug 2012 9:50am
mobilecentre
We can supply and fit LHD or RHD Wesbasto kits if you struggle Thumbs Up
Post #160268 6th Aug 2012 9:58am
excossack
OT: 5 cylinder engine? I thought the TDCi were a 4 pot engine? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #160269 6th Aug 2012 10:05am
jst
they are 4 pot. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160271 6th Aug 2012 10:12am
the webasto units are not left or right handed, but because mine is a LHD, I bought a fitting kit from Webasto Switzerland, I will be kicking myself if Tim at MobileCentre can get them Shocked
The units vary from £850 - £1100 depending on how nice the dealer is, and the unit comes with prettty much all you need for a standard installation, however I used the Swiss kit because it keeps the unit up out of harms way, easy to service etc.
The additional installation kit was about £200.
I was told the kits come with the timer unit but mine did not .. so I opted for the square one because I think it looks better on the dash.
I also opted to remove the fuel tank and install a seperate feed direct from the tank rather than "T" ing into the fuel pipes.
I also opted for the one-way valve as recommended by Daniele
All in, with my basic mechanical and electrical skills has taken about 3 days to install and test.
@Tim - if you need any info on the kit just drop me a PM but they are LHD only so I would imaging a low demand
Post #160274 6th Aug 2012 10:36am
jst
cheers BPman.
LHD bit was aimed at the veh rather than the install. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160278 6th Aug 2012 10:48am
mobilecentre
We are a direct Webasto dealer so can get the LHD & RHD fitting kits. As you say the thermo top C is universal. We fit ours under the wing using some custom brackets so it is out of the way.
When we fit one it is a full (LONG) days job to do it with two people on most of it.
Post #160279 6th Aug 2012 10:54am
excossack
jst wrote:
they are 4 pot.
I counted 5 injector pipes, or is one a return? 1999 Defender TD5 110
Regards
John M0VAZ
Post #160300 6th Aug 2012 1:09pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
excossack wrote:
jst wrote:
they are 4 pot.
The middle one, is the fuel rail high pressure supply line I believe.
Post #160301 6th Aug 2012 1:47pm
ericvv
Re: Webasto Block Heater Photos
bpman wrote:
just finished installing the webasto block heater, ...
What kind of heating system is this? To preheat the interior passenger compartment, or to preheat the engine coolant prior to winter cold starting? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160324 6th Aug 2012 6:09pm
jst
it does both Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160327 6th Aug 2012 6:27pm
BigRuss
Thumbs Up
For such good work, take the rest of the week off Whistle Russell
2011MY 110 XS USW Black
Post #160349 6th Aug 2012 7:34pm
dgardel
Italy
Very good job BPMAN!!! Thumbs Up Thumbs Up Thumbs Up
this is mine
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160364 6th Aug 2012 8:11pm
jst
remind me again why you need the one way valve? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160402 6th Aug 2012 9:31pm
Page 1 of 4 1234>
