Home > Puma (Tdci) > Gear lever
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Gear lever
Hi guys
So what do I need to do to replace gear lever on MY12 2.2 if I can justify buying a svx one
How does it release ? any special tools ?
Lee It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #158364 27th Jul 2012 6:31pm
BigRuss
What the did you do to it to need to replace it??? Russell
2011MY 110 XS USW Black
Post #158373 27th Jul 2012 7:28pm
sparkylee
Nothing just like svx one Embarassed It's good to be back from the dark side
FFRR 4.2 vogue
Post #158374 27th Jul 2012 7:34pm
K9F
No special tools....
All you need to do is push the gaitor downwards and lift two white quick release clips either side of the base of the lever, the lever will then just lift off. I've just done the same and replaced with an SVX one.
It has taken some considerable time but I have finally managed to source the SVX gear and transfer levers at significant discount against new prices.
To buy new from the dealers the pair would set you back over £1000...... Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #158378 27th Jul 2012 7:54pm
sparkylee
Thumbs Up Has to be done Bow down It's good to be back from the dark side
FFRR 4.2 vogue
Post #158433 27th Jul 2012 10:09pm
ericvv
Price is not illogical, no? They are meant to be installed only on the limited edition SVX. Whistle You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #158551 28th Jul 2012 7:45pm
K9F
Makes sense! That's how they outprice any Tom, Dick or Harry from kitting their vehicles out with SVX parts, thereby maintaining the uniqueness and attractiveness of the SVX to people who want them. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #158556 28th Jul 2012 7:56pm
I was looking at someone's parked up Defender 60th black special edition the otherday, very "doggy" people. The interior had been well chewed, and the gear levers, gaiters, centre console, and even the Recaros were all irrepariably chomped on. Enough to make grown men weep, but to the owner just another working Defender. Big Cry
Post #158766 30th Jul 2012 11:28am
K9F
I've not seen a 'working' SVX...anyone else? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #158774 30th Jul 2012 12:05pm
ericvv
Mine surely not... Whistle I keep it spic and span Thumbs Up
But must admit, a few weeks ago in the Geneva countryside also saw a local SVX90 in a rather mediocre condition. Not really a working vehicle, just some very careless owner Big Cry
Luckily this is quite unusual for Geneva, most people here are taking very good care of their Defenders. You never actually own a Defender. You merely look after it for the next generation.
Post #158818 30th Jul 2012 6:59pm
sparkylee
Think ones going on the shopping list in first place Very Happy It's good to be back from the dark side
FFRR 4.2 vogue
Post #158820 30th Jul 2012 7:04pm
dgardel
Italy
Mr. Green Whistle Whistle Whistle Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #205899 27th Jan 2013 12:57pm
K9F
Double post....friggin' pooter problems. Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #205953 27th Jan 2013 5:26pm
K9F
Unless of course an 'accommodating 'Italian Gentleman' sells you his brand new 'still packaged' SVX transfer lever to match a second hand SVX gear lever to finance his SVX grille purchase.
Thumbs Up Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #205954 27th Jan 2013 5:30pm
sparkylee
I'm still looking for a transfer lever Very Happy
Come on fellas there must be one out there that needs a new home Thumbs Up It's good to be back from the dark side
FFRR 4.2 vogue
Post #205976 27th Jan 2013 6:08pm
