![]() | Home > Puma (Tdci) > Double Din |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
colour wise i think nara bronze looks the mutts (as seen on the new x-tech ltd edition)
i'll see if i can find a pic. by the way - i really like the dash, too. ![]() |
![]() Click image to enlarge nara bronze ![]() |
tomachan Member Since: 31 Dec 2011 Location: Hong Kong Posts: 2 ![]() ![]() ![]() |
It really looks great! Please share details! Thousand thanks!
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Bronze looks superb
busdriver Member Since: 12 Oct 2011 Location: Hampshire Posts: 45 ![]() ![]() ![]() |
Thanks for everyones messages. I have taken onboard all the different things that you were after and have been busy making up some new fascias. It has taken a bit longer than I would have liked (
![]() I have ended up with 3 different designs which should cater for all the different combinations of accessories fitted to the Defender. I have made up one of each and painted them up in Brunel Chrome, here they all are: ![]() Click image to enlarge Last edited by busdriver on 17th Sep 2012 3:19pm. Edited 1 time in total |
patclan Member Since: 13 May 2010 Location: Gold Coast Posts: 20 ![]() ![]() ![]() |
They look great, been looking for something like this for a while.
Couple of question, is there any modifications required behind the console to allow the double din to fit? when i swapped my single din out it seemed a bit of a squeeze, do you have any photos of the space behind it and how is the 2 din unit mounted securely? thanks Patrick |
Patrick
Hi, you are right it is a bit of a squeeze to fit but it does fit. ![]() There are basically 3 small adjustments needed behind the fascia to fit the double din fascia. 1. You have to remove the piece of plastic running along the top of where the fascia sits (above the hazard light switch), 2. You have to cut the corner of the clock housing as it protrudes into where the stereo will sit (this was really worrying the first time but I couldn't believe an electric clock needed such a huge housing, which it didn't!) 3. Remove the single din mounting bracket. The cage fits in securely and the framework for the heating controls provides plenty of support. The first 2 can be done with a junior hacksaw, the hardest bit was removing the weird plastic lugs which hold the old mounting bracket. ![]() As i mentioned I fitted mine about a year ago and have never had any problems with it at all, with my Kenwood even the plastic trim fitted around the unit although this is the only bit that may be slightly to large and have to be adjusted or as the unit is recessed it can be fitted without it. I am busy with work till the end of next week but will then take my dash off and take a few pictures so you can see the adjustments needed. |
Thanks for that, don't go removing your dash on my account ![]() Great Mod, and now I have to save, hopefully you are still making them around November!! thanks for the reply. ![]() |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
i wont be collecting mine till october now
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
I’ve now received the double DIN fascia and I have to say how well it is made. In fact it’s better than the OEM. I’ve ordered the wireless, which should be delivered tomorrow and then, after a caravanning holiday, I’ll get down to fitting it in.
Thanks to busdriver for a job well done. Merlin |
stph712 Member Since: 16 Sep 2012 Location: METZ Posts: 2 ![]() ![]() ![]() |
Hello, I'm new on this site. I want to change my Def G4. Could you make another double DIN fascia with switch console like the central fascia on the picture ? Is it possible to have them in Orange Tangier color ? If it's ok could you give me the price for them ? Don't be surprised for my questions, i'm French and my English is not so good. But your work seems to be very perfect and i want to have one. Thank you very much for your answer. |
alsalloumabdul Member Since: 25 Nov 2013 Location: Kuwait City Posts: 3 ![]() ![]() |
Excellent job. I know it has been a long time since last update but I would love to have one of those. |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
You missed my PM. I am interested too
![]() SII or SIII in max 1.5k |
Hi alsalloumabdul I'm in Kuwait from 26th to 29th at Best Western hotel! mobile 65960136 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
