Home > Puma (Tdci) > Water Hose Warning
CapeLandy
South Africa
Water Hose Warning
Just by chance I noticed the top hose from the radiator is nearly worn through by rubbing on what looks like an electrical connection.
What I wanted to ask is whether this electrical connection is a Land Rover fitting or is it something an aftermarket installer may have fitted. It's a bit dark and cold to try and find where the wire goes right now.
I'll let the pics tell the story.
Apretiate some answers as soon as you can so I can call the dealer in the AM.
James
 Puma 110 - gone
Series III 1973 - going strong
Post #11707 8th Jun 2009 5:21pm
mse
Found it for you. Ive got the wire but it shouldnt run there.
You should be able to make it out from this picture
 Mike
Post #11710 8th Jun 2009 6:17pm
CapeLandy
South Africa
Thanks Mike
Does yours also have tape and sprague tubing as on mine?
Any idea what it's for?
James Puma 110 - gone
Post #11711 8th Jun 2009 6:52pm
mse
The guaze protects and strengthens the pipe the rubber ring keeps it i position Mike
Post #11716 8th Jun 2009 7:19pm
CapeLandy
South Africa
I meant on the electrical wire Puma 110 - gone
Post #11718 8th Jun 2009 7:22pm
mse
Yes but i seem to recall its tucked up in the wing Mike
Post #11719 8th Jun 2009 7:23pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
If it's any help, mine has the connector (for the ABS/TC sensor I think) clipped to the inner wing with a sort of tandem Terry clip. Looks like the clip is unique to that type of connector.
With the amount of cables, sensors and connectors under the bonnet now, it may be prudent to check if this sort of issue is evident elsewhere before something chafes through and becomes more serious.
Bosun.
Post #11771 10th Jun 2009 6:06am
CapeLandy
South Africa
Dealer had a look and cable tied the hose away and ordered new hose. Very Happy
 Puma 110 - gone
Post #11817 10th Jun 2009 7:17pm
CapeLandy
South Africa
new hose being fitted tomorrow - 3 sleeps till holiday Very Happy Puma 110 - gone
Post #12310 24th Jun 2009 8:41pm
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Also check the Inter cooler Hose rubbing against the pinch bolt on the steering column..
Post #12402 27th Jun 2009 12:09pm
