Home > Puma (Tdci) > Water Hose Warning |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Just by chance I noticed the top hose from the radiator is nearly worn through by rubbing on what looks like an electrical connection.
What I wanted to ask is whether this electrical connection is a Land Rover fitting or is it something an aftermarket installer may have fitted. It's a bit dark and cold to try and find where the wire goes right now. I'll let the pics tell the story. Apretiate some answers as soon as you can so I can call the dealer in the AM. James Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Puma 110 - gone Series III 1973 - going strong Last edited by CapeLandy on 8th Jun 2009 6:53pm. Edited 1 time in total |
8th Jun 2009 5:21pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5051 |
Found it for you. Ive got the wire but it shouldnt run there.
You should be able to make it out from this picture Mike |
8th Jun 2009 6:17pm |
Thanks Mike
Does yours also have tape and sprague tubing as on mine? Any idea what it's for? James Puma 110 - gone Series III 1973 - going strong |
8th Jun 2009 6:52pm |
The guaze protects and strengthens the pipe the rubber ring keeps it i position Mike
8th Jun 2009 7:19pm |
I meant on the electrical wire Puma 110 - gone Series III 1973 - going strong |
8th Jun 2009 7:22pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
If it's any help, mine has the connector (for the ABS/TC sensor I think) clipped to the inner wing with a sort of tandem Terry clip. Looks like the clip is unique to that type of connector.
With the amount of cables, sensors and connectors under the bonnet now, it may be prudent to check if this sort of issue is evident elsewhere before something chafes through and becomes more serious. Bosun. |
10th Jun 2009 6:06am |
Dealer had a look and cable tied the hose away and ordered new hose.
Click image to enlarge Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
10th Jun 2009 7:17pm |
new hose being fitted tomorrow - 3 sleeps till holiday Puma 110 - gone
24th Jun 2009 8:41pm |
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 |
Also check the Inter cooler Hose rubbing against the pinch bolt on the steering column..
27th Jun 2009 12:09pm |
