Home > Technical > 200 tdi or 300tdi ?
Flying Scotsman
Scotland 1989 Defender 90 200 Tdi PU Fuji Whte
200 tdi or 300tdi ?
Im going to replace my 90s old 2.5 td engine for 300/200tdi engine and I was just wandering, which engine is better Smile Defender 90
Disco 3
GSXR 750
Post #153141 1st Jul 2012 8:12pm
ickle
The best one is whichever you can get hold of in the right condition at the right price Thumbs Up
Keith
Post #153144 1st Jul 2012 8:15pm
Flying Scotsman
Is there any diffence between the two or are they quite similar ? Defender 90
Disco 3
GSXR 750
Post #153148 1st Jul 2012 8:19pm
Retroanaconda
Performance wise there is little difference. 300Tdi is slight more refined, 200Tdi is slightly easier to work on. Parts for 200Tdis are starting to get rarer, you get the idea. Apples and oranges.
As far as the conversion goes, it's easier to go from 2.5TD to 200Tdi than to go to 300Tdi, as the latter requires a bit of fiddling with engine mount brackets on the block etc. Noting insurmountable though.
If you're doing a 200Tdi, there are differences between using a Disco engine and a Defender one. The latter is easier to fit, the former required exhaust mods and different air pipework etc. Defender bits are 'plug and play' as it were....if you can find them. Obviously Defender lumps cost more!
I'm currently in the process of changing one of my 110s engine from 2.5TD to 200Tdi.
Post #153150 1st Jul 2012 8:24pm
ickle
300 is a more refined version of the 200, 200 pure mechanical fuel system, late 300 had some electronics I believe.
early 300's had batches of faulty pulleys that shredded the cam belts (all should be fixed by now) and susceptible to leaking P gaskets behind water pump.
Disco derived engines have low mounted turbos, interesting exhaust plumbing, Defender engines straight swap, also some extra studs to fit / drill out to mate to your bell housing.
If your 110 is a 1.67 transfer box it'll be horribly under geared, stick the disco 1.2 transfer box in, tweak the fueling and start enjoying driving again!
Keith
Post #153151 1st Jul 2012 8:30pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'd go for a 200 there the way forward gear box will bolt straight on its easy as said turbo is different on a disco engine but you can fits 2.5 td turbo on them it does fit or buy one of the manŷ kits they do to re pipe the problem
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #153173 1st Jul 2012 9:53pm
jst
200 will go onto 2.5NA and TD engine mounts and accept current gbox easily.
300 is more refinded, some say less mpg, some electrics on the later ones which can be bypassed anyway
200disco lumps are cheapest but you will need to modify the exhaust outlet and cobble together inter cooler trunking as nothing off the shelf fits as a bespoke kit. Still very easy to do though. Steve Parker do kits to all ow fitting but are quite £££.
200 def engines are now quite hard to come by and can command a premium - £750 ish the last one i sold went for compared to £250 for a disco lump.
i did do a thread on LR4x4 about fitting a disco lump, will see if i can find it. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #153193 2nd Jul 2012 5:54am
jst
http://forums.lr4x4.com/index.php?showtopic=18285
you may need to login to view Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #153194 2nd Jul 2012 5:58am
Zagato
Post #153203 2nd Jul 2012 6:59am
