Home > Technical > 200 tdi or 300tdi ? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1767 |
The best one is whichever you can get hold of in the right condition at the right price
Keith |
1st Jul 2012 9:15pm |
Flying Scotsman Member Since: 04 Jun 2012 Location: Not far from here Posts: 14 |
Is there any diffence between the two or are they quite similar ? Defender 90
Disco 3 GSXR 750 |
1st Jul 2012 9:19pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2615 |
Performance wise there is little difference. 300Tdi is slight more refined, 200Tdi is slightly easier to work on. Parts for 200Tdis are starting to get rarer, you get the idea. Apples and oranges.
As far as the conversion goes, it's easier to go from 2.5TD to 200Tdi than to go to 300Tdi, as the latter requires a bit of fiddling with engine mount brackets on the block etc. Noting insurmountable though. If you're doing a 200Tdi, there are differences between using a Disco engine and a Defender one. The latter is easier to fit, the former required exhaust mods and different air pipework etc. Defender bits are 'plug and play' as it were....if you can find them. Obviously Defender lumps cost more! I'm currently in the process of changing one of my 110s engine from 2.5TD to 200Tdi. |
1st Jul 2012 9:24pm |
300 is a more refined version of the 200, 200 pure mechanical fuel system, late 300 had some electronics I believe.
early 300's had batches of faulty pulleys that shredded the cam belts (all should be fixed by now) and susceptible to leaking P gaskets behind water pump. Disco derived engines have low mounted turbos, interesting exhaust plumbing, Defender engines straight swap, also some extra studs to fit / drill out to mate to your bell housing. If your 110 is a 1.67 transfer box it'll be horribly under geared, stick the disco 1.2 transfer box in, tweak the fueling and start enjoying driving again! Keith |
1st Jul 2012 9:30pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
I'd go for a 200 there the way forward gear box will bolt straight on its easy as said turbo is different on a disco engine but you can fits 2.5 td turbo on them it does fit or buy one of the manŷ kits they do to re pipe the problem
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
1st Jul 2012 10:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7889 |
200 will go onto 2.5NA and TD engine mounts and accept current gbox easily.
300 is more refinded, some say less mpg, some electrics on the later ones which can be bypassed anyway 200disco lumps are cheapest but you will need to modify the exhaust outlet and cobble together inter cooler trunking as nothing off the shelf fits as a bespoke kit. Still very easy to do though. Steve Parker do kits to all ow fitting but are quite £££. 200 def engines are now quite hard to come by and can command a premium - £750 ish the last one i sold went for compared to £250 for a disco lump. i did do a thread on LR4x4 about fitting a disco lump, will see if i can find it. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Jul 2012 6:54am |
http://forums.lr4x4.com/index.php?showtopic=18285
you may need to login to view Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Jul 2012 6:58am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Good guides here also
http://www.glencoyne.co.uk/info.htm |
2nd Jul 2012 7:59am |
