Home > Maintenance & Modifications > X-Trouser- daft name, clever idea
Page 3 of 3 <123
Finally fitted the last one today. Made a couple of shims from plastic cut from an old storage box and Bob's your mothers' brother:
A small tweak to one I'd fitted earlier and now all four doors shut with a satisfying thunk without the need to slam them Very Happy Darren
Post #154417 8th Jul 2012 9:50pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Fitted. Needed to tweak one as it was not quite square, easy fix. Could do with some proper shims at some stage but so far so good. Rhubarb and custard let fly with their secret weapon.
Post #154756 10th Jul 2012 4:33pm
IKke
Netherlands 1986 Defender 90 200 Tdi SW Keswick Green
My 90 (my 1986) has a protective cap around that pin shielding it from the side and the top. Scaling the real deal.
Post #154815 10th Jul 2012 7:54pm
SimonR
That's correct. Unfortunately the plastic sleeve is part of the problem. The plastic quickly becomes damaged and the door then fails to close properly.
After a bit of research, it turns out the purpose of the sleeve is to improve the sound of the door closing. We prototyped with and without a sleeve and found that without it both lasts longer and makes the door close reliably long term.
Once the sleeve became damaged, it introduced a new hook profile to the new part - removing its original advantage. Therefore we made the decision to omit the sleeve and produce a better quality, longer lasting product as a result.
Si
Post #154826 10th Jul 2012 8:13pm
ZeDefender
Damn! What is it about these clever little mods?
Perhaps my "skirt" might get caught one day Rolling Eyes
Must...resist...temptation....... Tell someone you love them today because life is short.
Post #154832 10th Jul 2012 8:23pm
I seriously hope not! Laughing TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #154833 10th Jul 2012 8:25pm
ZeDefender
Rrrrip... just discovered I might need one of these Embarassed Tell someone you love them today because life is short.
Post #160891 9th Aug 2012 8:27am
Tubes63
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
My God! This is genius!! I must get caught at least once a day... Geoff
2007 Defender 90
Post #161003 9th Aug 2012 8:17pm
Page 3 of 3 <123
