Home > Wheels & Tyres > Wheel and tyre help. |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I don't know much about wheels but these are the ones I have and they do not stick out.
The wheels are Compomotive 8.5 x 16 and have ET5 stamped on them. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
17th Jun 2012 9:58am |
WelshDefender Member Since: 02 Dec 2011 Location: Gwent Posts: 62 |
Thanks mate. Are they 285's??
17th Jun 2012 10:03am |
Oh yes sorry 285's
17th Jun 2012 10:05am |
Cheers. So hopefully I am right in thinking that with an offset of 0 the wheels will be very slightly further inside the arches than yours which should be ok. Wish there was a try before you buy so I could see what they are going to look like before I part with my hard earned!!
17th Jun 2012 10:08am |
It's the wheels that have the offset NOT the tryes. Fekete's wheels are the same size as mine 15 X 10....If memory serves me correctly he has 33 X 12.5 high flotation size boots on. I too have the same size wheels 15 X 10 but 'bottled it' due to not having a lift so went for 32 X 11.5 tyres. I do not have any fouling issues or MOT ones either. The offset is 40mm on Mach 5s. Karlos (Fekete) has some Mach 5s on order which I presume will be the same size as his current Modulars he also has a 2" lift. Dated photo... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Jun 2012 10:10am |
Crikey I am even more confused now!! So Fekete's wheels have an offset of -32mm (I think) and yours have an offset of +40mm?? So does that mean that Fekete's rims will stick out 72mm wider than yours will??
My head hurts |
17th Jun 2012 10:16am |
Where are you getting the -32mm figure from? You're confusing me too! If you go through life with your head in the sand....all people will see is an ar5e!!
17th Jun 2012 10:18am |
I asked Karlos about his wheels a little while back and he pointed me to the place where he got them from and all the 33's on that site were -32mm offset.
17th Jun 2012 10:20am |
Mine are negative offset sorry!
This helped.... http://www.nice-wheels.co.uk/pcdandoffset.html Off out now for Father's Day Lunch..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Jun 2012 10:46am |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 |
Welshdragon has the same alloys as mine, looking at his gallery. They are standard ones with regards to offset - ie. nothing added, nothing taken away.
On mine I have 225/65s and they reasonably 'flat' to the wheel. ie. they fit the rim really well, the tyres not being particularly wide. Looking at Welshdragon. the 265/75s look squashed out, as if they are only just fitting on the rim, being that bit wider than mine. I am currently looking at changing to 265/75s and will be getting rims with +8 offset to accomodate the extra width and maintain a good turning circle without rubbing on the hockey sticks. My other half has the same size tyres and rims on his 100" competition motor and are just right - they sit just about in line with the wheel arch, not quite sticking out. If unsure about what to get, I'd suggest asking those that know about these things - the big wheel/tyre sellers like Craddocks or Devon4x4. They can advise you on what wheel/tyre sizes work for different applications as they sell thousands of 'em! |
17th Jun 2012 12:57pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Like Pam says
As an example, Boost alloys have +33 offset which means that 33mm more of the wheel pokes inside compared to the mounting face. I changed to Dotz Dakar steel wheels with +8 offset. Decreasing this offset meant I could ditch my 30mm spacers as the wheels now poke out more by 33 - 8 = 25mm. My Cooper Maxx 265s sit just level with the arches and, IMHO, look just right (also good turning circle). ET8 + 265 = Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
17th Jun 2012 1:18pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
WelshDefender, Here is a tyre calculator to help you with what size tyres you pick .....also will tell you the different speedometer readings with bigger tyres...hope this helps
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
17th Jun 2012 4:23pm |
affiliate13 Member Since: 29 Jan 2012 Location: Belfast Posts: 82 |
Very useful site that.
17th Jun 2012 4:33pm |
17th Jun 2012 4:38pm |
