![]() | Home > Wheels & Tyres > Wheel and tyre help. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
https://s3-eu-west-2.amazonaws.com/i.hubnu...473fcb.jpg
285's on 8" zero offset silversports, the tread is covered just by the wheel arches, but they really throw the muck, dirt, road tar etc up the bodywork. Gearing etc is spot on though, slightly higher than std, speedo spot on, milometer, not checked. Keith Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Keith, I had the same issue....Here's the solution.... ![]() http://www.defender2.net/forum/topic5108.html?highlight=entreq If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks Mal,
I haven't got front flaps on, must get round to that, but at the back (on my 110), the muck seems to find its way between the bottom of the spat and the top of the mud flap, I've been looking for some mud flap type material (without going to the extreme of cutting truck flaps down) to make some new slightly wider ones, the rally blanks from Demon Tweeks and the like don't seem to be big enough. Keith |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2057 ![]() ![]() |
Might be useful to someone who wants to compare different wheel/tyre/offset sizes:
http://www.willtheyfit.com/index.php?width...mit=Submit or http://marksink.com/tire_wheel_offset/offset.html |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
and this
http://www.rimsntires.com/specs.jsp |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
let us know what you get, feel like i've lived it with you. good luck ![]() |
