Home > Puma (Tdci) > 110 sw Puma, Broken tube – but what is it?
rasmussen
France
Just realised a broken tube in the rear left wheel box – just above the exhaust pipe.
Could anyone educate me on what this piece of pipe is. Looks like some sort of ventilation?
Is it difficult to install a new one?
Cheers,
Post #149619 10th Jun 2012 8:25pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
looks like an axle breather possibly Confused
Post #149621 10th Jun 2012 8:28pm
ickle
fuel tank breather tube, axle breather is on the A frame
Keith
Post #149622 10th Jun 2012 8:32pm
Dave-H
As Keith says, it's the diesel tank breather .. Smile Guns and Landrovers .... anything else is irrelevant.
Post #149625 10th Jun 2012 8:39pm
they are supposed to be tucked behind the plastic plate in the background
Post #149629 10th Jun 2012 8:45pm
ickle
BP - is it not in a clip at the very top???
Post #149633 10th Jun 2012 8:59pm
Dave-H
Obviously missed its recall .... Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #149634 10th Jun 2012 8:59pm
MK
mine is showing cracks. Bad quality hose. Puma 110" SW
Post #149639 10th Jun 2012 9:34pm
Maxxed_Ross
it's worrying how low down that is then Shocked
Post #149652 10th Jun 2012 10:41pm
rasmussen
France
Thank you very much for your comments Very Happy
I have tried to find this part but very difficult to find.
I only found this:
http://www.brit-car.co.uk/product.php?xProd=160379
but over 30 quite Shocked !! for a plastic tube - that even brake very easy Big Cry
Have anyone experience with ordering parts directly from brit-car?
Post #149797 11th Jun 2012 8:06pm
bob neville
I use Brit Car all the time for parts. Never a problem but can take a while to send as they supply a lot of genuine parts that have to be ordered.
2013 Defender 90 CSW - sold
Post #149799 11th Jun 2012 8:17pm
landy andy
Just buy a bit of fuel pipe that is the correct diameter, and use a jubilee clip to join it to the original rigid section, that has the one way valve.
Andy
Post #149801 11th Jun 2012 8:21pm
Andy
And extend it higher ....
Post #149870 12th Jun 2012 8:17am
oldyella76
Australia 2012 Defender 110 Puma 2.2 SW Indus Silver
I joined mine to length nylon fuel line and ran it along the top of the chassis rail to the engine area and put it up high against the firewall then joined the valve to the end of it. When you wish to bleed the fuel system just blow a bit of compressed air down the tube and it will prime the system for you.
Ragards Lindsay. Lindsay
Post #149873 12th Jun 2012 8:46am
dgardel
Italy
And move the pipe behind the plastic plate.
There is a recall for it. In that positiin you can have water/dirty ingress inside the tank and future problem with the water up tu damage the common rail high pressure pump and injectors. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #150183 13th Jun 2012 4:54pm
