Home > Td5 > Brakes failing??
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Brakes failing??
Evening all,
On the way to work tonight a very peculiar and worrying thing happened, I was approaching a roundabout and applied the brakes for obvious reasons and all of a sudden the brake pedal appeared to travel a lot further than normal, I was in auto-pilot mode really, not day dreaming or anything like that, but when you apply brakes you don't always gauge the travel but it did appear strange and the braking was very poor and I had to release and press down again, then the brakes were normal again, to be honest, they actually felt a little sharper than before. Now I'm not sure if my foot was wet as it has been raining or disc's were wet for the same reason but it all felt a bit odd as I was not expecting it and was not really paying attention, the brakes feel fine now and I must have looked like a bit of a lunatic to nearby motorists as I was pressing the brakes quite randomly and firmly whenever I was clear of traffic to test them, like I said, they feel a bit better than before, anyone else had this? what should I be looking for apart from empty fluid reservoir and fluid on wheels etc.
thanks in advance.
Mike
I have posted this on another forum, but I figured the more opinions I get the better Thumbs Up
Post #148809 5th Jun 2012 9:34pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
apart from the master cylinder I would also check for a sticking caliper, especially at the rear. BM52
Post #148813 5th Jun 2012 9:55pm
jst
or loose caliper bolts Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #148844 6th Jun 2012 6:18am
landy andy
Check your wheel bearings
Andy
Post #148849 6th Jun 2012 6:59am
noworries4x4
Andy
+1
Especially the front ones. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #148857 6th Jun 2012 8:08am
taffrican
Andy
Thanks for the replies, but, what effect can wheel bearings have on the brakes?
Post #149168 8th Jun 2012 12:16pm
If the bearings are gone, the discs wobble and push the pads back in, so they need to travel further when you press the brake...
My guess is your abs block is goosed...like mine was Neutral
Post #149177 8th Jun 2012 12:52pm
taffrican
Thanks all, found the culprit, it is the offside rear caliper, seized on me whilst going to work again. I carried out a quick check the other day and all appeared ok but then out of the blue there was a grinding noise coming from the back, jacked it up and all was revealed Neutral new discs and pads in tomorrow and service the caliper a bit too Crying or Very sad .... I bet it p*sses down all day tomorrow too Big Cry
Post #149713 11th Jun 2012 11:00am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Just did my rear brakes, here is the kit list (I know you didnt ask, but in case you find it useful..Wink)
1. Rear Brake Discs
LR017953 £120.92 PAIR
2. Rear Brake Pads
SFP000270 £50.74
3. Rear Brake Calipers
RH LR005952 £122.05
LH LR005950 £142.38
also a £30 surcharge on the above caliper so old one will need to be returned
4. Any hub seals etc that I need to replace when removing brake discs
FTC4785 X 2 £7.38 pair
571752 X 2 £1.62 PAIR
5. Anything else I need when replacing complete rear brakes..!
RFD100000 X 2 (Hub lock nut) £7.86 PAIR
FTC5241 x 2 (Hub lock washer) £3.48 PAIR
My calipers were siezed and the pads themselves were crumbling, I dont do much mileage, so it think it was just down to lack of use and crappy weather..!
cheers
simon
ps Sorry, should have said this list is for a 2001 TD5 with ABS/TC, not sure if that makes a difference..
Post #149722 11th Jun 2012 11:25am
taffrican
Thanks for the info Simon, I was hoping the calipers would have just required cleaning and free-ing up a bit, they were worse than I thought, the one side was seized solid and no movement of the cylinder/piston at all, I'm on nightshift this week so they will be coming to work with me and a full overhaul with stainless pistons to be fitted. Hopefully that should be it Thumbs Up
Post #150145 13th Jun 2012 12:11pm
