Home > Puma (Tdci) > Puma gearbox overfill ?
Page 1 of 3 123>
grat
Netherlands
At a recent servicing, the gearbox of my Puma Defender was not filled with the 2.2 litres of gearbox oil but to the brim of the filling hole. Does anyone know how much is in the gearbox now ? Is it a risk and should it be drained and refilled or is there no reason to worry ?
Post #147640 30th May 2012 7:30am
jst
i have always filled to the filling hole. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #147641 30th May 2012 7:36am
Naks
Overfilling (i.e., to the hole instead of measuring 2.2L) ill result in the hot oil eating at one of the seals (can't remember which one) and a leak will ensue. --
Post #147649 30th May 2012 8:42am
jst
so its a fill plug rather than level plug then/
is this specific to the Puma Gbox only? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #147653 30th May 2012 8:53am
Naks
I think so. My indie mech also thought he had to fill it to the plug, I told him not to. --
Post #147654 30th May 2012 8:54am
MartinK
Yes the Puma manual says measure out 2.2 litres...
On mine this was about 3mm below the filler hole. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147682 30th May 2012 12:11pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Yip!
According to the Puma Workshop Manual it is NOT a level plug like in the Td5 but in the Puma only a filler plug and you have to stick to the prescribed amount of oil apparently.
Post #147687 30th May 2012 12:28pm
grat
Netherlands
Thanks everybody ! I will drain and refill to the correct level.
Post #147699 30th May 2012 12:57pm
Tim_NZ
Australia
I had about 4.5 litres come out of my 110's gearbox, looks like it got filled twice! I put the recommended 2.2l back in and it runs cooler now Smile
Cheers,
Tim
Post #147836 30th May 2012 11:39pm
Molusk
France 2008 Defender 130 Puma 2.4 HCPU Alpine White
What kind of oil did you put in your gearbox?
As the recommanded one does not exist anymore, I do not know which oil I must get to refill mine.
Thanks for helping me.
julien.
Post #147868 31st May 2012 8:55am
Naks
For the Puma?
Anything that conforms to WSD-M2C200-C specs --
Post #147872 31st May 2012 9:15am
MartinK
Gearbox uses GL-4
Have a look at the Opie Oils website
They list 4 oils for your Defender Gearbox (and a wide price difference!).
The one which is often well reviews is Millers Oils TRX Synth 75w-90 full synthetic gear oil... Link here: http://www.opieoils.co.uk/p-60227-millers-...r-oil.aspx
This Castrol would probably be the closest equivalent to the "standard" LR-recommended oil: http://www.opieoils.co.uk/p-744-castrol-un...ersal.aspx
Last time i changed the oil I used this: http://www.opieoils.co.uk/p-739-castrol-sy...5w-85.aspx - seems to work fine Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147876 31st May 2012 9:29am
Molusk
Thanks mates! Very Happy
although these oils are very expensive... Embarassed
Post #147878 31st May 2012 9:40am
MartinK
Agree they are expensive.
My last Land Rover had a R380 gearbox, and at 187000 miles, it had significant wear, and replacement would cost around £1000.
I made the decision to service my new Defender frequently and use top quality lubricants, so as to get the best life I could out of her!
If you stick to the book maintenance schedule, most owners will only ever change the gearbox oil once or twice ("normal" use says 200,000km between gearbox oil changes), so IMHO it's a job worth doing well! That's why I bought fully synth good quality oil... I'll use fully synth top-quality oils, and change them every 2nd year. Hopefully it'll be more economical in the long run by making the gearbox last a very, very, long time Thumbs Up
Last time I changed the engine (inc filter), gear, transfer and diff oils, the bill was around £150 just for lubes and the filter Shocked Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147880 31st May 2012 9:49am
Molusk
When I wrote these lube are very expensive, I didn't mean I would prefer to put cheap oil in my gearbox. I was just comparing the prices on your links, to the price I can get the same oils in France (Castrol Syntrans Multivehicle 75w90 is about 8£/liter VAT incl. here). Moreover, I used to get the oils for my landies to a wholesaler at about 3£/liter... but it is not Castrol.
Post #147881 31st May 2012 10:05am
Page 1 of 3 123>
