![]() | Home > Maintenance & Modifications > Good idea or stupid - Sound proofing method |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
OK mateys what do you think.
Been thinking about the engine compartment sound proofing options and I know all about the lead blankets and adhesive pads etc but what about this? As the inside of my bonnet is sprayed with Dinitrol, sticky pads would be a faf. So what if I was to remove the bonnet and fill it with expanding fire proof foam which when set firm could easily be trimmed around the edges for a neat smooth finish. I would guess it would have reasonable sound proofing qualities, be fire retardent and dead easy to do and because the Puma bonnet has lots of gaps it should hold in place regardless of the Dinitrol. Any drawback? What am I missing? ![]() http://www.uksealants.co.uk/product.asp?idproduct=201 ![]() Mermoto[/img] |
No Please!!!!
Low sound proofing capacity (too much lighter and closed cell) and it trap the water / humidity.................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
DGARDEL - how are you getting on with the acoustic cover off the 2.2 installed on your 2.4 ??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
..but wouldn't expanding foam be closed cell so not able to absorb water? ..is humidity likely to occur under the bonnet, I realise that the engine can be very hot and outside at night the temperature can fall way below but I have never seen any condensation on the inside of the bonnet. Also with the foam in direct contact with the underside would that not prevent water droplets forming? Just thoughts ??? Mermoto |
Water can goes from metal surface and foam.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Not Yet ![]() ![]() ![]() But I want to do during this weeks Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
....... At a glimps I thought you were going to put the cup of foam in the 'Cup holder' on the engine, lol.
![]() ![]() ![]() Glyn ![]() ![]() |
I'd say that stuff is too light-weight to offer any significant sound proofing qualities. Vehicle sound proofing usually relies on density. Darren
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
isn�t highly flamable? Puma 110" SW
No, it's 'fire rated expanding foam'. Its' intended use is stopping of holes through fire rated walls, ceilings, etc. around services and the like in buildings. Darren
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Could be sprayed behind the dash to stop those pesky rattles
![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
And imagine what fun you'd have afterwards when trying to find the cause of that 'random' short circuit.
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
I did think about filling the chassis with expanding foam to stop water getting in and to prevent condensation
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1847 ![]() ![]() ![]() |
It absorbs water, don't do it!
