![]() | Home > Maintenance & Modifications > tyres "again"! |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
Sorry to bring this up again but ive searched the forum trying to find out what are the LARGEST BFG mud terrain tyres I can fit to the standard boost alloy without any modification by way of spacers and suspension lift. I want to order a set today. Found all the threads rather confusing as most of the lads have done some form of modification to get big tyres to fit. If any body has a pic of the largest fitted tyre without modification it would be most appreciated. Land Rover's don't leak oil, they simply mark their territory!
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
285's will fit but not recommended as a minimum of 7.5inch rim is needed. 265�s no problem.
cheers
lekker my china
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
I have 265/75 on my 90 with standard suspension height, they rub on the front radius arms at full lock but look great!
just tried to order 265/75/16 but there is a 12 week wait as there are only 12 in the country and all have been reserved. I think I might have to order 8 and store 4 for future purposes. Land Rover's don't leak oil, they simply mark their territory!
Martin,have you adjusted the lock stops ? 2.4 90 XS
Nope - it's one of those "round tuit" jobs from 9 years ago
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
Martin,
I dont suppose you have a Pic of the truck with big tyres on do you. DEFENDER XS CSW 08 TONGA GREEN |
Loads here: http://www.web-rover.co.uk/nav.php?p=gallery
Damn! That's the size I wanted to get. What's the solution for the rubbing (I'm at full lock a lot to get in and out of my drive)? If I fit spacers, will they add significant wear to the bearings or front diff? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
3 point turn
![]() I think that 235/85s might be better on a 110? 0.2% difference |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8207 ![]() ![]() ![]() |
or CVs assuming your offroad CV acting through greater angle etc. most people i know who have had spacers have got rid of them, problems keeping them done up - get different rims with a greater off set or adjust the nuts to stop the rubbing and live with a worse turning circle. 110s have tonnes more lock than they leave the factory with if you adjust the lock nuts. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
ii I have these as needed the clearnace to fit snow tyres espically on the back wheels |
