![]() | Home > Technical > Steering clonk |
Could be the coil spring moving in it's seat. 2.4 90 XS
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
CV joint or steering ball joint
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
CV is like a loud clicking sound in the early stage (don't leave this to long or it will let you down at the worse time). A clonck could also be a bush gone on the front raidius arms.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Could be a loose jack under the seat. Have a look in the seat box. 1982 88" 2.25 diesel
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Check your swaybar connections. I had the same issue when one of the connecting bolts fell out.
Tim |
